what type of flange do you need for a 3 inch down pipe?
Old Mar 8, 2003 | 08:08 PM
W.Zero's Avatar
Default what type of flange do you need for a 3 inch down pipe?
i want to get a 3 inch down pipe made but dont know what type of flange to get for a t3/t04e. can anyone help?
thanks
les
Old Mar 8, 2003 | 08:13 PM
baddassduramax's Avatar
Default Re: what type of flange do you need for a 3 inch down pipe? (W.ZeroB18C1T)
i was wondering the same thing
Old Mar 9, 2003 | 06:42 AM
johnisenglish's Avatar
Depends on what Turbine Housing your using.
If it's five bolt go with a five bolt flange
If it's four bolt go with a four bolt flange
Both can be found here: http://store.yahoo.com/cheapturbo/cuspic1.html
Old Mar 12, 2003 | 05:30 AM
W.Zero's Avatar
Default Re: what type of flange do you need for a 3 inch down pipe? (johnisenglish)
ive looked at that sight and the flange there seelling is the one i bought but the muffler guy said it wont fit a 3inch. i bought the 5 bolt flange.
just like this one. this is from that web site.
W.Zero's Avatar
if there a different please show me. thanks
Old Mar 12, 2003 | 05:59 AM
g2turbo's Avatar
that is the correct flange. Your exhaust wheel on the turbo is probably only 2.5" anyways so you just tack a 3" piece to the standard 2.5" downpipe flange and go from there. Or you could use your other downpipe(2.5") if you have one and leave a short section of 2.5 then flare to 3".
Hope this helps. CHRIS
Old Mar 12, 2003 | 09:53 PM
W.Zero's Avatar
Default Re: what type of flange do you need for a 3 inch down pipe? (g2turbo)
yeah thats how i have it now 2.5 flare to 3 but i see everyone that has a 3in right from the flange and that looks much better. ill take the flange to another guy a see what he saids. thanks for the info.
les
Old Mar 12, 2003 | 09:58 PM
Full-Race Javier's Avatar
u could try a vband
http://www.full-race.com/vbanddownpipe/
2001ZincSR
Nov 25, 2005 04:48 PM
BDaTurboTeg
May 27, 2005 07:24 PM
TeamShiftPoint
Dec 16, 2004 11:11 AM
92HB_HB
Feb 24, 2004 05:21 PM
94TurboGSR
Sep 21, 2003 10:51 PM
