how much boost with 370's?
Old Mar 8, 2003 | 04:07 PM
zojirushi's Avatar
Default how much boost with 370's?
How much boost can one run with rc 370cc injectors on say hondata?
Old Mar 8, 2003 | 06:21 PM
SpoolnG2's Avatar
Default Re: how much boost with 370's? (zojirushi)
safely, i'd say probably about 12-13psi
Old Mar 8, 2003 | 06:38 PM
B20-T's Avatar
Default Re: how much boost with 370's? (Jtsintegra)
7psi
Old Mar 8, 2003 | 06:48 PM
SpoolnG2's Avatar
Default Re: how much boost with 370's? (B20-T)
u can run 7psi on stock injectors. just get a walbro 255lph intank and 370's can for sure handle 12 psi. now if your motor can handle i don't know..but the size of the injectors can for sure.
Old Mar 8, 2003 | 06:58 PM
vtec.dc2's Avatar
its not about the boost, its about hp.. 370cc are optimal for low 200's whp, but you can raise pressure and maybe extend to 250-270.. but the higher you go, the more you'll be pushing it.. i hope to get away around 230-250whp - but if theres too much pressure or high duty cycle on injectors - i'll upgrade to 440's
Old Mar 9, 2003 | 01:33 PM
zojirushi's Avatar
Default Re: how much boost with 370's? (vtec.dc2)
are you running on hondata?
Old Mar 9, 2003 | 02:32 PM
vtec.dc2's Avatar
yes, hondata.. also 255 high pressure intank fuel pump.
B18 rider
Aug 8, 2008 10:51 AM
turbo*s2k
Feb 25, 2004 11:50 AM
r7
Jul 13, 2003 02:17 PM
SIK IN DA HED
May 14, 2002 02:53 PM
WykidEH
Oct 12, 2001 03:38 AM
