question about dsm injectors in a 4th gen
Old Mar 8, 2003 | 07:09 AM
spankaveli's Avatar
Default question about dsm injectors in a 4th gen
ive done a search, i know how to hook it up and everything, but i have two questions which i haven't found answers for.
1) will the honda injector plugs plug into the dsm injectors, or will i have to modify the plugs?
2) will the dsm injectors fit into the d16 intake manifold or will i need to modify the o-rings or anything?
thanks alot
spanky
Old Mar 8, 2003 | 07:23 AM
Tinker219's Avatar
Default Re: question about dsm injectors in a 4th gen (spankaveli)
electrically they will plug up. Orings have to be either ground out, or doubled up on in order to seal properly
Old Mar 8, 2003 | 08:04 AM
spankaveli's Avatar
so am i correct in understanding that because the 4th gen civic already has a resistor box because (from what i read) the older hondas had peak-hold injectors so they needed the resistor in the car stock? that means i should just be able to plug in the injectors, no splicing or anything?
thanks again.
Old Mar 8, 2003 | 09:05 AM
Tinker219's Avatar
step one: Unplug stock injectors
step two: plug in dsm injectors
step three: bolt back in. if a good seal isnt created around each injector, take the plastic spacer out from behind each I.M. oring, and replace with another I.M. oring...ie, double up on orings...
step four: done
wmac547
Engine Management and Tuning
Apr 8, 2014 06:43 PM
lshatch59
Jan 7, 2007 08:01 AM
Simple
Jul 6, 2003 02:29 PM
flat-blk-HB
Jul 9, 2002 10:09 AM
