Emissions question
Old Mar 7, 2003 | 06:23 PM
Jaker's Avatar
Default Emissions question
We have a carbed 1985 CRX that we are trying to get tested for emissions. The car is failing the idle test because of excessive carbon monoxide levels. Does anyone know how to reduce CO emission, without causing any of the other readings (HC, NOX) to rise?
Old Mar 7, 2003 | 06:53 PM
Spade's Avatar
Default Re: Emissions question (Jaker)
New catalytic converter and lean that SOB out.
Old Mar 7, 2003 | 07:51 PM
Qfactor's Avatar
Default Re: Emissions question (Spade)
you're running to rich have the smog techs to check the O2 with a DSO scope to see if its working properly and also have them do the one of the four catalytics tests to check the efficiency of it. i would check the neddle seats they may be leaking too. if it is a carb vehicle.
hellaflushdb2
Jul 6, 2011 10:04 AM
b20vtecturbe
Sep 30, 2009 08:19 AM
blueg6
Feb 10, 2009 07:11 PM
Jdmtuned
May 5, 2006 09:55 PM
