Whats the most boost you can get away with on stock sleeves?
Old Mar 7, 2003 | 02:09 PM
9krpm's Avatar
From: see my earring from a MILE, bling bling, Va, USA
Default MAX BOOST on stock sleeves?
Ive got a stock b16 block w/ je 9:1 pistons and eagle rods and wondering how much boost i can get away with with 550 injectors and hondata 2b
[Modified by Boosted2ksi, 6:15 PM 3/7/2003]
Old Mar 7, 2003 | 03:05 PM
nonvtec allmotr's Avatar
Default Re: MAX BOOST on stock sleeves? (Boosted2ksi)
BUMP for you! id like to see what people have to say also...
Old Mar 7, 2003 | 03:09 PM
dmecarboy's Avatar
Default Re: MAX BOOST on stock sleeves? (nonvtec allmotr)
I have a stock block 20 over. je 9:8.1, eagle rods, crower valvetrain, golden eagle block guard. I run 550cc with apexi power FC, I push 18-20 psi daliy. made over 400hp at the wheels. Tuning is the key!!!
Old Mar 7, 2003 | 03:22 PM
CRX SiR T's Avatar
Default Re: MAX BOOST on stock sleeves? (dmecarboy)
old setup: stock b16 motor, golden eagle blockgaurd, 550cc injectors, Zdyne, turbo kit.
ran 17lbs all night long. ringlands broke before anything else
get a blockgaurd if you are sticking with stock sleeves
Old Mar 7, 2003 | 04:05 PM
silverkorn's Avatar
check this thread
https://honda-tech.com/zerothread?id=435363
that was a b18c1 with stock sleeves running 19psi running the hatch into low 11's
like stated before tuning is the key, with the near perfect 1.74 R/S ratio and proper A/F tuning then you should be able to boost 19psi without a problem.
i personally have srp 9:1, eagle rods, and a blockguard on a b16 and looking to push near 20psi at the track. i would be more worried about running max duty on your injectors before anything on a good tune
Old Mar 7, 2003 | 04:44 PM
jinxproof99's Avatar
New User
Default Re: MAX BOOST on stock sleeves? (silverkorn)
i ran about 26 lbs on a t4 in my street car. stock sleeves, built motor, haltech, and 8 injectors.
Old Mar 7, 2003 | 06:23 PM
Cyber ITR's Avatar
Default Re: MAX BOOST on stock sleeves? (jinxproof99)
well jinxproof prolly ur stock sleeves stronger than any other stock sleeves
Old Mar 7, 2003 | 07:18 PM
silverkorn's Avatar
Default Re: MAX BOOST on stock sleeves? (SEX DR)
thee thing is there is no standard saying you can run x amount of boost with y pistons. just the air temp or elevation differences can change the whole tune enough to blow a motor. and with parts from honda they are never the same, thus why the have the whole color system with the bearings.
Old Mar 7, 2003 | 07:36 PM
hatchii's Avatar
looks like i'll be running 12psi with a stock b16a1 block.
Old Mar 8, 2003 | 07:16 AM
New User
you must not know much about hondas. there are hundreds of cars in the us boosting 20 lbs of boost on stock internals. i did not reinvent the wheel, just copied many other peoples set ups. if you don't know ****, keep the comments to yourself. thank you.
Old Mar 8, 2003 | 07:17 AM
NX_LS's Avatar
What turbo? If it's small like a T04B...lots of boost. If it's like, a T66, then not much.
CarAudioPro
Dec 6, 2005 09:37 PM
dunkd
May 31, 2004 08:06 PM
Jer Del Sol
Nov 10, 2003 10:35 AM
skellator_thoj
May 19, 2003 05:08 PM
Trajic
Aug 22, 2001 02:35 PM
