LIp fitment SUCKS!
i bought a Lip and the fitment sucks *** its the EK mugen style lip made for an EG...well i pulled the end over the bumper and it cracked any ideas on what to do?
Do you have any pics of where it cracked? I know a lot of times you have to "massage" aftermarket kits/wings/lips to fit correctly. When I used to install them, I'd use a dremel to clean things up.
Actually, that spot commonly cracks on aftermarket lips front and rear. If it's made out of rubbery/plastic type material, it's most likely polyurethane. If it feels like plastic, it's probably fiberglass. Fiberglass can be patched up and repaired fairly easy, there' are repair kits available everywhere, including Home Depot. If it's poly, you can try a plastic bumper repair kit available at Kragen, Autozone, etc. The problem is that the lip is too small to fit around the edge of the bumper, so the bumper needs to be trimmed a little, try a Dremel for that job.
that's way you sure make a bracket to support.suspense it instead of bolting it down with nuts and bolts.
when you lip scape the ground the metal bracket move instead of your lip taking the blow.
kinda hard to explain, not the wimpy braket come with the lip but custom made one.
you probbly got it from Ebay (like me
) and it it too short to fit the bumper, and the sides stick out. fits like ****! i gues you gotta get the real one.
Scott
who did you buy it from...
and why would you buy an ek lip for an eg lip, you do know that they make eg mugen style lip as well...
_______
I bought it from a local shop for 50$ and read the question again...its and "EK style mugen lip" not an EK mugen lip...its the one for EG's
_______
If its urethane, shouldnt it not crack that easily? hmm...
My mugen style lip is black plastic i think. Fits pretty good tho.
here is a pic of mine, look how the sides stick out. i need to get a real one instead of the shitty replicas that dont fit. I think it makes the car look much more meaner.
here is a pic with out the lip
it had a sticker on the inside that said for 92-95 3 dr. unless they put the wrong sticker on it, i dont know. i would like to get another one though, it looks nice but this time i will make sure it fits before i paint it
, waste of paint.
, waste of paint.
solved my problem...i used a cheesegrater thingy and grined the **** out of the sides and it fits...now i need to Drill holes and its done...the lip is actually not that bad fit wise its jus short and u can Pull or force it at all...could u use a heat gun and move it around..if so that would be alot easier
cilvia
10
Nov 13, 2005 08:35 AM
