HELP!!! Is this LSD BAD? or Fixable?
Old Mar 7, 2003 | 01:13 PM
H22AMedina's Avatar
Default HELP!!! Is this LSD BAD? or Fixable?
here is a link to my pics folder.. i took them today
http://www.imagestation.com/album/?id=4290572233
the pics i am refering to are the ones where my thumb points to a dent.. what do you think?
it's a used jdm h22 lsd.. it came like that
Old Mar 7, 2003 | 01:17 PM
Kamin's Avatar
Default Re: HELP!!! Is this LSD BAD? or Fixable? (H22AMedina)
ouch...
that looks tough.
i personally wouldnt put it in my car, but it could work fine. there is a little clearance between the 2 pieces but still..
Old Mar 7, 2003 | 01:37 PM
H22AMedina's Avatar
Default Re: HELP!!! Is this LSD BAD? or Fixable? (Kamin)
does anyone know if its replace able? do they sell those in the US?
Old Mar 7, 2003 | 01:50 PM
acura_typer's Avatar
Banned
thats just a bearing. you can get a replacement from Honda. Have a shop pull that one and install the new one. I would get two new ones, one fro each side.
Old Mar 7, 2003 | 01:56 PM
H22AMedina's Avatar
Default Re: HELP!!! Is this LSD BAD? or Fixable? (acura_typer)
yeah, but the thing is that lsd's for a prelude wasn't offered in the states... so why would they have parts for it?
Old Mar 7, 2003 | 01:58 PM
Banned
it'll be the same bearing as the standard prelude.
Old Mar 7, 2003 | 01:59 PM
BigMoose's Avatar
If the hardened surfaces look good on the bearing. Take a flat punch from the inside and a "tapping" hammer and work the dent out. Buck the cage on either side of the dent with two other hammers. You should only tap on the cage, not the race or the rollers. Don't try to get it perfect, just better. That assembly was dropped on the stamped steel retainer. No big deal. I "know" how to work that dent out, but its damn hard to explain on the internet.
That kind of thing would be an issue on a very high speed bearing, but if it was in that kind of application it would be a ball bearing with a phenolic two part cage.
Regards,
BigMoose
Old Mar 7, 2003 | 02:21 PM
sgT's Avatar
sgT
Default Re: HELP!!! Is this LSD BAD? or Fixable? (BigMoose)
just replace the bearing. its cheap.
Old Mar 7, 2003 | 02:32 PM
Nameless RB26's Avatar
Default Re: HELP!!! Is this LSD BAD? or Fixable? (sgT)
Looks like your LSD is 100% fine. Bearings are cake to replace.
What did you do? Drop it?
Old Mar 7, 2003 | 03:24 PM
H22AMedina's Avatar
Default Re: HELP!!! Is this LSD BAD? or Fixable? (Nameless)
I got it like that shipped from Canada
so I can just go to the dealer for the replacement?
Old Mar 7, 2003 | 03:26 PM
H22AMedina's Avatar
oh and thanks everyone for the replies.. I was a bit worried
Old Mar 8, 2003 | 05:59 AM
Yah, you can go to the dealer or get one from acuraautomotiveparts.net and get the bearing for the 97 spec ITR tranny, it will be the same.
SilverEK96
Transmission & Drivetrain
Jul 21, 2015 05:30 AM
jdm inc
10
Sep 11, 2011 03:29 PM
fjt
Apr 12, 2005 05:18 AM
showbiz
Apr 14, 2004 11:51 AM
flip1199
Aug 25, 2002 09:22 PM
