Almost done, need little help though.
Old Mar 7, 2003 | 01:09 PM
dc2pffsssttt's Avatar
Default Almost done, need little help though.
Heres the thing. Everything is put together, i pull a relay so that it doesnt crank over, but it starts up, just to see if the oil like will spit out oil to my turbo. I took the wire off the turbo and put it into a can. I start it several times, i get out, and i see no oil. Whats up with that?? Do I need to actually have the engine run to have oil squirt out of there? what do you think is wrong??
Old Mar 7, 2003 | 01:22 PM
BoostingSnail's Avatar
Default Re: Almost done, need little help though. (dc2pffsssttt)
Is the engine freshly rebuilt??
And how long are you holding the key??
Old Mar 7, 2003 | 01:38 PM
MikeMAN's Avatar
u need the engine to crank, just not start. just start the car, although the turbine will be moving...its not like ur gunna be boosting. Just shut it off as soon as u see oil come.
mike
Old Mar 7, 2003 | 01:39 PM
Default Re: Almost done, need little help though. (BoostingSnail)
The engine wasnt rebuilt, it was just a turbo install. I see some oil underneath the car now, i can see where its coming from though but it may be the reason that im not gettin pressure for the oil to go through the line. Damnit this is frustrating.
Old Mar 7, 2003 | 01:42 PM
MikeMAN's Avatar
i would check where u t'd off the block in the back, it seems like that is where its leaking...use teflon tape if you haven't already
mike
arsenaldragster
Dec 21, 2006 05:54 AM
Tad
Jun 25, 2005 08:56 PM
y0y0
Apr 10, 2005 01:13 AM
2000vsm
Aug 29, 2003 07:06 PM
DOHCarp
Nov 26, 2002 11:30 AM
