Overheating...HELP
Old Mar 7, 2003 | 08:18 AM
BoostedSi's Avatar
Default Overheating...HELP
My friend has a eg with b18c motor. New waterpump, radiator, new pusher fan, and thermostat. We also just retorqueed the arp head studs last night. Please let me know if anyone can help...thanks
Sam.
[Modified by BoostedSi, 5:18 PM 3/7/2003]
Old Mar 7, 2003 | 09:12 AM
brcivic411's Avatar
Default Re: Overheating...HELP (BoostedSi)
more info please. give us the scenario of what happens
Old Mar 7, 2003 | 10:16 AM
fukaintmuven's Avatar
Default Re: Overheating...HELP (brcivic411)
if u just retorqued the head bolts you might of stripped one(ones enough)... did they all torque with easy? because the headgasket might be expanding and let oil/anifreeze mix... check ur oil to see if there is milky resedue.... almost brownish... gl
Old Mar 7, 2003 | 04:23 PM
BoostedSi's Avatar
Default Re: Overheating...HELP (fukaintmuven)
It overheated before we retorqued the studs. One member on here said that his studs losened and overheated his motor so we thought that might have been the problem. "This is y we retorqued them; just to be safe. Just checked the oil and it looked just fine.
Could it be a crimped hose?? Thanks
Sam.
Old Mar 7, 2003 | 10:19 PM
does it overheat while at idle parked...?? wait u bought a pusher fan right?? becareful with those things... when i bought mine, i justy hooked it up thinking that that either way it would push blow air through radiator..... place a piece of paper and see if the paper is sucked throught the radiator(into it)... the air should be blowing the paper towards the motor... just check. i know it sounds dumb but when i switched over that was my problem
Old Mar 7, 2003 | 10:30 PM
MikeSarr_GSR's Avatar
did you use a hondata intake manifold gasket
Old Mar 8, 2003 | 10:58 AM
BoostedSi's Avatar
i flipped the blades so that it pushes. I can feel the air blowing through.
Old Mar 8, 2003 | 10:59 AM
BoostedSi's Avatar
Default Re: Overheating...HELP (MikeSarr_GSR)
Nope
EDIT: Problem fixed. THanks
jaron_cc
Apr 3, 2009 07:33 PM
crvtkllr
Mar 29, 2007 01:00 PM
angelSIR-G
Feb 21, 2007 10:09 AM
HamiltonRex
Jul 5, 2006 06:55 PM
junior40er
Jun 20, 2006 09:35 AM
