how do i turn off this check engine light??
Old Mar 7, 2003 | 04:10 AM
blazin99si's Avatar
Default how do i turn off this check engine light??
Ey yo guys im in need of some assistance/ Ive got a 99 Si & a few months ago a friend of mine who will never touch my car again almost blew my engine by getting water into the spark plug shafts and although i got all water out and my car is running fine tha check engine light has come on and off and now will not turn off, its been on for like a month now at least/ anyone know how to get it turned off and stay off??
Old Mar 7, 2003 | 04:32 AM
torr's Avatar
Default Re: how do i turn off this check engine light?? (blazin99si)
either disconnect your battery or take out the fuse, i forget which fuse it is . it's the fuse box by the battery.
Old Mar 7, 2003 | 05:28 AM
tpr's Avatar
tpr
Default Re: how do i turn off this check engine light?? (torr)
Have you checked to see what code is being displayed? Before just trying to make the light go out, better find out why its on in the first place. If you just want to "turn it off" warm the car up. Then, with the car shut down, pull the "hazzard" fuse on the passenger side fender well. Leave it out for 30 seconds or so then put it back in and start the car. This will reset the ECU and allow it to "learn" the idle parameters (OBD 2). Find out what's wrong!
Old Mar 7, 2003 | 05:37 AM
blazin99si's Avatar
Default Re: how do i turn off this check engine light?? (tpr)
Do you know how i could find out whats wrong without paying mad loot?? aka how i could do it myself??
Old Mar 7, 2003 | 05:50 AM
JimBlake's Avatar
AutoZoned will read the code for free. At least the ones near my house .
When they tell you what it is, write down the code number, nut just the guy's explanation. I had 'em read P1457 on a '98 Accord, he said it was loose gas cap. According to Helm, that code means unable to hold vacuum in the EVAP canister system, nothing to do with the gas tank itself.
Old Mar 7, 2003 | 06:00 AM
andrewasf77's Avatar
why not search, you can easily pull the code yourself with a paper clip, check it out
Old Mar 7, 2003 | 06:16 AM
JimBlake's Avatar
Default Re: how do i turn off this check engine light?? (andrewasf77)
'99 is OBD-2, I don't think it does the OBD-1 paper-clip-trick. You need to plug in an OBD-2 reader, which looks like a calculator with a wiring harness.
Old Mar 7, 2003 | 06:26 AM
Sleeper's Avatar
Pull the back up fuse(7.5) from the underhood fuse box for ten seconds and then replace it. If the code comes back, short the 2prong service connector above the passenger side kick panel with a paperclip. This works for 99 and 00 SI, and all other bseries I've tried it on. Read the check engine light flashes, long flash =10's, short flash = 1's.
Old Mar 7, 2003 | 06:59 AM
Default Re: how do i turn off this check engine light?? (JimBlake)
not true, i have jumped my 97 type r that is obd2 a few times
Old Mar 7, 2003 | 08:30 AM
MachAF's Avatar
This is how you get codes
http://www.c-speedracing.com/faq/06.php
This is what codes mean
http://www.c-speedracing.com/faq/05.php
Good Luck
Old Mar 12, 2003 | 07:54 AM
turbochic's Avatar
yeah you can jump it, i did it on my 97 civic OBD 2. Auto Zone told me how to do it.
Old Mar 12, 2003 | 08:14 AM
genetsang's Avatar
why doing you just go to a local shop and have the code read.... obviously theres a problem and thats why the CEL is on... its better to be safe then sorry...
Old Mar 12, 2003 | 01:29 PM
JimBlake's Avatar
Default Re: how do i turn off this check engine light?? (fmaxturbochic)
Cool. How about a '98 Accord? I gotta look for that in the Helm book...
Old Mar 12, 2003 | 04:00 PM
T3's Avatar
T3
Default Re: how do i turn off this check engine light?? (machaf)
http://www.cspeedracing.com/faq/05.php
Good Luck
Ty..Heres a for all your troubles.
[Modified by T3, 7:00 PM 3/12/2003]
ericrcan
Nov 24, 2012 07:54 PM
Cdeese910
Oct 25, 2012 07:56 AM
10KrpmS2K
Honda S2000
Aug 11, 2005 07:36 PM
liquidscor00
Jun 24, 2005 11:56 AM
