Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Opinions on adjustable timing gear brands?
Old Mar 6, 2003 | 05:34 PM
CRX Lee's Avatar
Default Opinions on adjustable timing gear brands?
Searched but didn't find anything.
Anyone have brand preferences on adjustable timing belt pulleys? This is on a SOHC D16A6. I've never actually used one. Sold the unused race engine that had an AEM pulley on it. Know Unorthodox makes them too. Years ago heard complaints about Skunk2s for not having clear increments but that may have neen changed. Need to order one pretty soon. Input is appreciated.
Old Mar 6, 2003 | 06:16 PM
upstatecrx's Avatar
Default Re: Opinions on adjustable timing gear brands? (CRX Lee)
i've got a skunk 2. don't have any trouble reading the increments. i'll see if i can get a pic tomorrow. i had a hayame adj gear and the skunk 2 is prob about half as light as the hayame.
Old Mar 6, 2003 | 07:55 PM
89civicdx's Avatar
Default Re: Opinions on adjustable timing gear brands? (upstatecrx)
I use a Fidanza gear but found the locking nuts to be pretty stupid as when you loosen them they end up spining off the bolt...falling off...once into my timingbelt cover
If they had allen key bolts then I would say they are good...pretty light and clearly marked and cheap too.
IMO The best I've seen so far is the skunk2...very light with allen key bolts I'm going to replace my fidanza with the skunk pretty soon.
Old Mar 6, 2003 | 08:16 PM
Krispy's Avatar
Default Re: Opinions on adjustable timing gear brands? (89civicdx)
I bought a AEM Tru-Time Cam Gear last year. The previous owner of this mystery engine said he was running 12 advance and the engine had a cam in it(he took the cam gear off when i bought the engine). After a trip to the dyno i found that +2 advance worked best(must be a pretty mild cam..ggrrrrr).......money well wasted right?
But anyway, the cam gear worked great, easy to use and read. However make sure you have a inch/lbs torque wrench as the gear required torque to 15ft/lbs.
[Modified by Krispy, 5:17 AM 3/7/2003]
Old Mar 7, 2003 | 07:48 PM
CRX Lee's Avatar
Default Re: Opinions on adjustable timing gear brands? (Krispy)
I ordered the Unorthodox Street gear today since I already have their crank and alternator pulleys.
Old Mar 8, 2003 | 04:33 AM
Eee Pee's Avatar
I was going to recommend JG/ Edelcrack. 100 bucks at Jegs.
5 allen heads, clear indicator marks, and so forth...
UR = big money.
Old Mar 8, 2003 | 08:32 PM
CRX Lee's Avatar
Default Re: Opinions on adjustable timing gear brands? (Eee Pee)
Workin' all the angles
Old Mar 8, 2003 | 08:46 PM
Want2race's Avatar
well ive only heard that the AEM slips... so avoid that one!
Old Mar 8, 2003 | 11:42 PM
TRE_'s Avatar
Default Re: Opinions on adjustable timing gear brands? (Want2race)
i'm running AEM tru-times on my ZC, and i havent had any problems with them. only reason that i can think of that would make them slip would be not torquing the bolts down correctly.
Old Mar 9, 2003 | 07:02 AM
CRX Lee's Avatar
Default Re: Opinions on adjustable timing gear brands? (glowing_rotors)
I did notice that the Unorthodox race gear had 5 locking bolts and the street one I got has 4. The AEM Tru-time gear that went with the engine has 3. The more bolts the more weight but also the more locking power (if all were tightened equally).
[Modified by CRX Lee, 4:03 PM 3/9/2003]
Old Mar 9, 2003 | 07:48 AM
89civicdx's Avatar
I used a AEM on my DOHC ZC and never had a problem the bolts "lock" in place so unless you don't tighten them properly I don't see how they would slip.But its nice to have more bolts for piece of mind.
It would be nice if someone had a chart comparing cam gears(weights/# of bolts etc)
Old Mar 9, 2003 | 06:10 PM
Krispy's Avatar
yep, mine has never sliped either. Just torque them properly and all is fine........
JayDaTroll1
Aug 3, 2018 12:11 AM
j4s0n1337
Feb 15, 2012 03:07 PM
Svery
Feb 8, 2010 01:21 AM
chitty024
Feb 28, 2008 03:13 PM
Slammd Sol
18
Aug 15, 2005 05:48 PM
