Highest Compression on a B16 Daily Driver
Old Mar 6, 2003 | 04:11 PM
7rrivera7's Avatar
Default Highest Compression on a B16 Daily Driver
What would you guys say would be the highest/safest compression I could use (pistons) for a daily driver on pump gas (premium of course). I'm currently running JE SRPs at 10.5:1. I was looking at Type Rs which are 11:1 but I worried they are not forged like the JEs and I want to run nitrous.
If anyone can suggest a particular brand which will have off the shelf pistons without having to bore my block, let me know.
Old Mar 6, 2003 | 04:16 PM
PhatOptimo's Avatar
Default Re: Highest Compression on a B16 Daily Driver (7rrivera7)
A little over 12:1 is the highest I would go. I run a little over 11:1 (ctr slugs) right now with 93 and have no detonation. OEM pistons do not take large doses of nitrous very well (they shatter). OEM pistons can handle some nitrous, but a 100+shot and you'll need forged pistons.
[Modified by Phat_Optimo, 7:17 PM 3/6/2003]
Old Mar 6, 2003 | 05:59 PM
TREVER's Avatar
Default Re: Highest Compression on a B16 Daily Driver (Phat_Optimo)
13-1 on pump gas 91octane with good tuning, but good luck getting it with a b16 crank.
Old Mar 6, 2003 | 06:03 PM
fukaintmuven's Avatar
Default Re: Highest Compression on a B16 Daily Driver (TREVER)
Damn.. please tell me what kind of ecu and who tunes your cars... i tried running CTRs and JEs both were 13.0-1 and i detonated both on 94 octane.... ur the man i need to talk to...
Old Mar 7, 2003 | 04:25 PM
TREVER's Avatar
Default Re: Highest Compression on a B16 Daily Driver (fukaintmuven)
Hondata
Old Mar 7, 2003 | 09:58 PM
TimoneX's Avatar
New User
You can't run too much timing advance and you must avoid leaning out, but it can be done.
Old Mar 7, 2003 | 10:05 PM
Goldfingiz's Avatar
Just a note, ITR's will lower your compression in a B16 and CTR's will give you 10.8:1
Old Mar 11, 2003 | 05:11 AM
7rrivera7's Avatar
Default Re: Highest Compression on a B16 Daily Driver (Goldfingiz)
This was your response to my question on the highest safe compression on a B16 with stock gas. Thanks for the info - I thought the Type Rs would give me 11:1. Do you know of any off the shelf forged piston that will give me 11:1 - 11:5? I was looking at Arias but they have 12:1 and I'm worried it's too high.
Old Mar 11, 2003 | 09:10 AM
AllmotorJunkie's Avatar
i think 11:1 is kool. Dont want to have the early detonation problems most people have when going 12+ compression.
Old Mar 11, 2003 | 09:57 AM
dfoxengr's Avatar
Default Re: Highest Compression on a B16 Daily Driver (Tailpipe Observer)
12.5
Old Mar 11, 2003 | 10:00 AM
Cashflo's Avatar
Default Re: Highest Compression on a B16 Daily Driver (hybridvteceg)
im in cali with 91 pump. i would go 11.3-11.5:1. just my .02
remember ctr pistons(pct) in a stock b16 only yield a 10.8:1 compression ratio
[Modified by eghead, 11:02 AM 3/11/2003]
Old Mar 11, 2003 | 10:02 AM
Katman's Avatar
Default Re: Highest Compression on a B16 Daily Driver (eghead)
ditto.
[Modified by Katman, 11:02 AM 3/11/2003]
Old Mar 11, 2003 | 10:34 AM
PhatOptimo's Avatar
Default Re: Highest Compression on a B16 Daily Driver (Katman)
Which compression calculator is correct?
http://www.c-speedracing.com/howto/c...c/compcalc.php
or
http://www.bojangs.com/calculator/
Kinda funny that the both give different compression ratios when selecting the same parts. I put in B16a block and head with CTR (PCT) slugs OEM (3 layer) headgasket 81mm bore.
C-speed says 10.80:1
Bojangs says 10.99:1
JDMHP told me It would be 11:1 when I bought the pct pistons
I wonder whos is actually correct.
Old Mar 11, 2003 | 11:07 AM
Kataku2K3's Avatar
This is true, meaning that the only OE pistons that will generate a higher C/R are P30's and PCT's... 10.8:1 isn't all that much and you won't have any problems tuning that out... With 310-370cc injectors and a VAFC you can easily tune out 12.0:1 on 92.... Drop your timing back down to ~12 degrees and you shouldn't detonate at all... I would still recommend Hondata because it really isn't that much more than a VAFC and has a lot more parameters... IGN timing mapping through the rpm band, etc... To achieve ~12.0:1 you're gonna need aftermarket pistons... Look into JE and Endyn.. I like them both....
How did you get 13.0:1 with PCT slugs??? I'm just curious, even in an 81.25mm LSVTEC running a P72 cylinder head you'll still be in the mid to low 12's... (~12.3:1) Was this in a B16?? That would be even harder due to the shorter stroke and the PR3 cylinder heads 1.1cc bigger CC.. Was your head milled or did you have a high compression headgasket... Again I'm just wondering... I can see that C/R with aftermaket pistons... Peace
Old Mar 11, 2003 | 01:50 PM
Katman's Avatar
or
how about we just leave it at a ballpark of 10.8-11.0ish, yeah?
a .3 difference isn't really that noticeable.
7rrivera7
Aug 1, 2005 06:01 AM
KillaB-
Sep 19, 2004 06:01 PM
No
10
Jul 15, 2004 08:04 AM
jackedcrew
Mar 28, 2004 07:44 PM
Erik_Pb_Foot
Feb 1, 2002 03:05 PM
