Need help with my swap...ONCE AGAIN!!!
Honda-Tech Double Platinum Member
Well i finally got all the electrical **** hooked up and started on the coolant lines. I was doing good until i ran into a little snag. On the firewall side of the tranny there is a round thing with two hoses coming out and a place on the top to put another hose or something. What is this? And where do the hoses go on my engine and what goes on the top of it?. Thanks.
Sean
Sean
Reads like you are describing the VSS and the 2 tubes that come out of it. Put your speed sensor wire in the vertical hole and call it a day. Leave the other ones open.
I was thinking that it was the VSS but the tubes were sorta throwing me off. Will this VSS work with my car? I hope it will because i want the speedometer. Thanks.
Sean
Sean
Louis53123
Feb 6, 2006 09:21 PM
Hypertek99
Apr 11, 2005 07:13 AM
