dh-racing d16 160 wheel hp worth it or not?
Old Mar 6, 2003 | 05:37 AM
untitled's Avatar
Default dh-racing d16 160 wheel hp worth it or not?
dhr builds d16's with 160 whp. what will this get me down the 1/4 in with a car that weighs about 1650 lbs. do you think it is worth it? it costs 2025 long block.
Old Mar 6, 2003 | 06:28 AM
PaImportTuner's Avatar
Default Re: dh-racing d16 160 wheel hp worth it or not? (88crx91integra)
mid 13s with some good ol tuning.. or atleast i would be in the 13s.
[Modified by PaImportTuner, 3:30 PM 3/6/2003]
Old Mar 6, 2003 | 06:57 AM
CLICC916's Avatar
is it built for drag? street? autox? road racing? where does the power come in? what do you want your motor to do in regards to the previous questions? it sounds like you're going to be dragging, the car should be reasonably fast, mid 13's sound right....2025 in some places is the going rate of b series....but in my opinion, turbo will be the best way to go unless you're going for NA
Old Mar 6, 2003 | 07:42 AM
untitled's Avatar
Default Re: dh-racing d16 160 wheel hp worth it or not? (CLICC916)
will more likely be street. closer to drag. suspension wise probably just some tokicos and good coilovers. i will run steelies with slick at the track.
Old Mar 6, 2003 | 02:20 PM
Heavy Pee's Avatar
What is dhr? whats their website? thanks
Old Mar 6, 2003 | 02:49 PM
altoid's Avatar
Default Re: dh-racing d16 160 wheel hp worth it or not? (Hvy P)
knowing what i know thats about the max hp you can pump out of an a6 running pump gas and no induction. If thats what you want go for it, or build a turbo beast or get a b that'll make upper 200s running pump gas.
you could probably run 12s i think Wil from exospeeed had his hf rex run 12s with an NA built a6 running pump gas
[Modified by altoid, 6:56 PM 3/6/2003]
Old Mar 6, 2003 | 05:55 PM
untitled's Avatar
Default Re: dh-racing d16 160 wheel hp worth it or not? (altoid)
ww.dh-racing.com is the site. i could always giggle gas the motor.
Old Mar 12, 2003 | 07:10 AM
Charlie Moua's Avatar
check out http://www.exospeed.com or IM ExospeedAMcrx(wil)
he's a great guy to talk with and they have a lot to offer the true D16 fans out there. and their prices are better (.. I think)
Old Mar 12, 2003 | 07:42 AM
ExospeedAMcrx's Avatar
no dont do that... its not as fun. too easy.
Old Mar 12, 2003 | 07:53 AM
spun Vtec's Avatar
Default Re: dh-racing d16 160 wheel hp worth it or not? (exospeedAMcrx)
and keep compression in mind if its a high c/r motor build for na i wouldnt shoot it
...unless you are going to buy a scattersheild
allmotor2.1
Mar 31, 2008 06:11 PM
slimthug
Jul 29, 2005 06:06 AM
RIP V8s
Jul 9, 2005 02:06 PM
Shu
Feb 18, 2004 02:23 PM
Pinhead
Jan 31, 2002 06:18 PM
