gt35....too big?
gt35....too big?
ok i have searched and came up with nothing but classifiedsa bout this beast. but what i am asking is it going to be too big for a built 2.0 lsvec at 8.5-1 comp? will be running this on a one fab topmount and 4 inch dp. thanks any responses welcome
Re: (TurboChrgd_Civic)
this car will be tuned only on 116 mostly just something to mess around with on the street and once in awhile at the track
Re: gt35....too big? (downeyballz)
i have sufficient amount of 116, pretty much as much as i want...
any ways is the sraight t4 too big the s housing, i know there is different housing and all
Re: gt35....too big? (b20vrex)
HOW CAN WE TELL YOU IF IT'S "TOO BIG" IF WE DON'T KNOW HOW MUCH POWER YOU WANT!
If you want 200 WHP yes, it's too big.
If you want 700 WHP yes, it's too small.
You said "big power" but that doesn't tell us dick. To some big power is 500 WHP. To some it's 300. For others it's 800.
Re: gt35....too big? (b16sedan)
The gt35r should do the job I would imagine, depending on your goals.
You'll have no problem making 500 whp and It will spool pretty quick compared to alot of the other 500-600 hp turbos.
I think a few people have made over 600 whp with a 35r, If these are your power goals, I would Recommend the T4, especially with a top mount. the standard T3 housings are such a PITA in comparision.
calm down man trying to make between 550 and 600 whp........ and will a tial 38 be enough for this? 25+ psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vrex »</TD></TR><TR><TD CLASS="quote">calm down man trying to make between 550 and 600 whp........ and will a tial 38 be enough for this? 25+ psi</TD></TR></TABLE>
I would recomend a 44mm tial
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vrex »</TD></TR><TR><TD CLASS="quote"> will a tial 38 be enough for this? 25+ psi</TD></TR></TABLE>
good enough for most of the domestic's making 500-700whp.....l
Re: gt35....too big? (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd »</TD></TR><TR><TD CLASS="quote">
good enough for most of the domestic's making 500-700whp.....l</TD></TR></TABLE>
Unless you are trying to run less boost on the street, then you are screwed
Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd »</TD></TR><TR><TD CLASS="quote">most of them run below 11 for DD...that i know
my friend mike is running 6lbs with a PT67 GTQ and a 38mm and doing just fine. this is with a profect b spec 2 as well</TD></TR></TABLE>
If Mike can do that then he's one extraordinary person. I have trouble holding a turbo with a smaller hot side to 9 psi with a tial 44mm gate on a tubular mani.
Re: (b16sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16sedan »</TD></TR><TR><TD CLASS="quote">If Mike can do that then he's one extraordinary person. I have trouble holding a turbo with a smaller hot side to 9 psi with a tial 44mm gate on a tubular mani.</TD></TR></TABLE>
cool, it's called an inferior manifold design
Re: (rhd)
cool, it's called an inferior manifold design</TD></TR></TABLE>
Full-Race is inferior now?
Re: (b16sedan)
Full-Race is inferior now? </TD></TR></TABLE>
uh... no.
uh... no.
Re: (Tomcat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomcat »</TD></TR><TR><TD CLASS="quote">
uh... no.</TD></TR></TABLE>
It's called sarcasm, champ.
Re: (b16sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16sedan »</TD></TR><TR><TD CLASS="quote">Full-Race is inferior now? </TD></TR></TABLE>
considering some owners are having to use 2 wastgates...i suppose so. also, the unnecessary use of thick wall material, thus creating a HUGE heat sink that heat soaks everything within 3 square miles adds to the poor design as well.
doemstic guys don't have issues with it....maybe design a manifold that's focused more on wastegate than the turbo..and you'll solve the problem
Re: (rhd)
i have heard, from other manifold fabricators, that extra thich walls doesnt help performance at all it just adds extra weight. its great because you will never have to worry about the manifold breaking and it will last forever, but i thinner walled manifold will last just as long if it is braced correctly and will weigh alot less.
with that being said, i am very happy with my love fab manifold because i know its the last manifold i will need to buy (extra thick tubing = wont break)
Re: (rhd)
yeah a lot has to do with manifold design and wastegate placement. like the hytech manifold papadakis had on his fwd car the path of air went strait to the wastegate and the turbo sat off to the side.
