i have no vtec , please help (did search couldnt find anything usefull)
Old Mar 5, 2003 | 06:32 PM
riceboyEFsi's Avatar
Default i have no vtec , please help (did search couldnt find anything usefull)
i am using a pr3 reprogramed by eriks racing , some things were removed from it such as secondary o2 , knock , and vtec pressure send. unit. The reason i removed the vtec pressure sending unit was because i was using a vafc . Anyways oil level was good , car was very warm , speedo cable was plugged in, wiring was good . I even tried my friends stock pr3 and same results. This car once had a ls/vtec and it worked fine and nothing was changed besides not having a vafc anymore . No codes either Any ideas guys? thanx >> e
Old Mar 5, 2003 | 06:34 PM
icelarry27's Avatar
Default Re: i have no vtec , please help (riceboyEFsi)
i know when vtec doesn't work, alot of times the vtec solenoid isnt hooked up right, so you may wanna doulbe check on that, check all your connections and everything. see if your check engine light comes on at all. good luck
Old Mar 5, 2003 | 06:38 PM
Default Re: i have no vtec , please help (GRCuadros)
wiring is good no cel's , no codes
Old Mar 5, 2003 | 07:24 PM
2000blackgsr's Avatar
is your knock sensor hooked up?
Old Mar 5, 2003 | 10:11 PM
Default Re: i have no vtec , please help (96coupe)
the knock sensor was removed from the ecu when it was reprogramed, so no
Old Mar 6, 2003 | 01:20 AM
NiiS's Avatar
Long shot, but check if the screen on the oil pressure sensor is clogged with debris...
No oil pressure=no VTEC, as well as low oil level
Old Mar 6, 2003 | 05:10 AM
sikgsr's Avatar
On your VAFC, Make sure the Blue wire (I think Blue, Its been awhile) is hooked up to the Oil Pressure Wire out of the ECU. Without this, it Will fall flat on its face a couple of times, then wont let you rev past 5K. Resetting the ECU temp fixes this but will do the same thing after a few redline sweeps.
SIK
Old Mar 6, 2003 | 08:49 AM
Default Re: i have no vtec , please help (sinister)
i checked this when i put the head on the block it was clean
Old Mar 6, 2003 | 08:50 AM
Default Re: i have no vtec , please help (sikgsr)
SIK
the funny thing is i can rev the **** out of it way past 5k , also like i mentioned i dont have a vafc anymore
Old Mar 6, 2003 | 09:01 AM
sikgsr's Avatar
Id check the wiring on the harness that plugs into the ECU. Check all the conncections again where you removed the VAFC wiring from.
SIk
chachi1080p72
Nov 16, 2007 04:20 AM
fstdsm
Jul 17, 2007 03:38 PM
sheepey
Jul 29, 2004 04:21 AM
r7
12
Jun 13, 2002 10:21 AM
