is a -4an line to big for oil feed???
Old Mar 5, 2003 | 03:37 PM
boosted_dc2's Avatar
Default is a -4an line to big for oil feed???
just like the title any info would be appreciated thanks!!! Drag 3 kit 94 gsr
Old Mar 5, 2003 | 03:51 PM
Midwestrider's Avatar
Default Re: is a -4an line to big for oil feed??? (hooked_up_gsr)
It will be too big.. get a -3an feed line.
Eric
Old Mar 5, 2003 | 03:56 PM
AlphaKennyWun's Avatar
Default Re: is a -4an line to big for oil feed??? (Midwestrider)
I use it
Old Mar 5, 2003 | 04:05 PM
SiRkid's Avatar
lots use -4
Old Mar 5, 2003 | 04:07 PM
93LSivic's Avatar
Default Re: is a -4an line to big for oil feed??? (SiRkid)
I use -4 now, but im getting some oil past the seals. Just ordered the -3 feed kit from Arturbo...should be here any day now.
I would sugguest the -3.
Old Mar 5, 2003 | 04:10 PM
B20-T's Avatar
Default Re: is a -4an line to big for oil feed??? (93LSivic)
use -3
Old Mar 5, 2003 | 04:15 PM
TurboDANDEE's Avatar
Default Re: is a -4an line to big for oil feed??? (B20-T)
-3 as well, i heard -4 feeds too much oil.
Old Mar 5, 2003 | 04:40 PM
ZCHF's Avatar
Default Re: is a -4an line to big for oil feed??? (TurboDANDEE)
anyone know where to get the return flange that hooks to the turbo and the one that goes into the oil pan? thanks
Old Mar 5, 2003 | 04:57 PM
silverEH2's Avatar
thats what i heard
Old Mar 5, 2003 | 05:10 PM
ls-t del sol's Avatar
Default Re: is a -4an line to big for oil feed??? (ZCHF)
VS Racing
Old Mar 5, 2003 | 05:12 PM
ZCHF's Avatar
Default Re: is a -4an line to big for oil feed??? (SolReaver)
what is the vs racing link? also, what is the equivalent inch size to an -10 line. thanks
Old Mar 5, 2003 | 05:15 PM
raverjames21's Avatar
Use an oil restrictor inline. I might decide to get a -4AN line setup. For now I will probably just use -3.
Old Mar 5, 2003 | 05:19 PM
boostaholic's Avatar
-10AN = 5/8"
Old Mar 5, 2003 | 05:40 PM
blufke's Avatar
Default Re: is a -4an line to big for oil feed??? (boostaholic)
-3an = 3/16ths? -4an = 4/16ths?
Old Mar 5, 2003 | 05:42 PM
Default Re: is a -4an line to big for oil feed??? (blufke)
Correct.
Old Mar 6, 2003 | 07:02 AM
Poop111444's Avatar
Honestly, I ended up buying -3AN line, but a guy that works at http://www.turbo-performance.com email'd me this in regards to his oil feed kit for $79, which is a great deal for everything you get.
"Kevin we use a -4an. if your worried about something with the -4 its more complicated than just the dia. of the oil feed line Im sure you have heard the 4 will blow out your seals. there is a long list of reasons that will blow that seal. also cars that use t-3 turbos-from the factory use a -4an there are two key reasons for blowing that seal.
1.poor placement or flow in return line
2.inferior internal compents inside turbo.(some rebuild kits are notorious for leaking)that is by internal part manufacturer= $500 hybrid turbo price would denote inferior components. Stick with the -4an and install return line properly to avoid blown oil seal. "
Old Mar 6, 2003 | 07:10 AM
legendboy's Avatar
Default Re: is a -4an line to big for oil feed??? (si_mekanik)
My friends and I use -4 oil feed and none of us have had any problems....but if you have a blown turbo then you will....
I always thought that if you used a -3 line the velocity of the oil would just be higher and if you used a -4 line it would move more slowly so I don't see the big deal....
Old Mar 6, 2003 | 07:18 AM
*Boostwerks*'s Avatar
I blew the oil seals on my old T-25 with a -4an line.
No matter what size line your running, I would ALWAYS wait for the car to warm up, to let the oil pressure come down.
Old Mar 6, 2003 | 07:34 AM
Farnsrocket's Avatar
Default Re: is a -4an line to big for oil feed??? (Bryson)
I use -4........no problems.
Old Mar 6, 2003 | 07:38 AM
b18bturbo's Avatar
Default Re: is a -4an line to big for oil feed??? (Farnsrocket)
i been using -4 for years and years since probably 95 geez thats what drag was sending way back when in the orginal drag gen 1 kits..
Old Mar 6, 2003 | 07:46 AM
Smashback's Avatar
Here's the deal..if you are using the Sunpro 1/8 BSPT to 1/8 NPT adapter, it basically acts as an oil restrictor because the inner hole is VERY small.
Other brand adapters, not sure.
If you get that Turbo Performance kit...just wait until the steel braid on the return gets all frayed because they used cheap clamps instead of hose ends. That stuff will tear you up when you try to take it off someday. If you're gonna use clamps, use regular rubber hose for God's sake!
Old Mar 6, 2003 | 07:48 PM
Default Re: is a -4an line to big for oil feed??? (Hatchblack)
what would you recoment then??? i dont want crap thats why im redoing my oild sending/return set up...i dont car how much it is i hate leaks!!!!
Old Mar 6, 2003 | 08:07 PM
Arturbo's Avatar
Better than steak
25 Year Member
Ive always used -3, but -4 also works. -3 is what my rev-hard was shipped with in 95. jk
You guys are over thinking things.
Old Mar 7, 2003 | 07:40 AM
SuperT's Avatar
Default Re: is a -4an line to big for oil feed??? (Arturbo)
I use only -4 but -3 will work as well. Turbonetics recommends -4 or -3. You cant have too big of an oil inlet...You could stick a -10 on there with no problems, remember, it is a restricted pressurized inlet and it is psi not volume that is the issue. Psi will be the same no matter what size line within reason. The turbo bearing will only flow so much oil depending on the clearance...running a bigger oil line to it will not make it flow more oil or psi. Its just like having a bigger fuel rail, the injector will only flow so much...Or like having a bigger battery, the starter will only draw what it needs..
Hope this helps...
Dave
[Modified by SuperT, 4:48 PM 3/7/2003]
hondaeg8
May 23, 2006 11:53 AM
88da3
Feb 1, 2006 03:47 PM
Prelude91siT
Jan 19, 2004 06:24 AM
aracer69
Sep 9, 2003 02:04 PM
sk8rmike
Jul 22, 2003 07:54 PM
