SOHC or swap?
Old Mar 5, 2003 | 03:26 PM
EtotheG's Avatar
Default SOHC or swap?
alright... heres the deal.. i have a 92 sohc vtec hatch... basic bolt ons.. and road racing suspension... should i swap(b16 or b18) or build up the SOHC?? NEED SOME IDEAS!!
Old Mar 5, 2003 | 03:57 PM
SteveeeO's Avatar
Default Re: SOHC or swap? (SOHCvtec92)
it really depends on what you plan on doing... they both have potential and money takes you where you wanna go, I say if your going turbo, build up the SOHC - if your going NA, get a b18
or just get a b18, build it, then turbo it... whatever fits your needs
Old Mar 5, 2003 | 04:01 PM
EtotheG's Avatar
Default Re: SOHC or swap? (SteveeeO)
but i kinda want to keep ot the ultimate sleeper... pop the hood... all u see is the SOHC but had monster *****... but i seriously just dont know cause my friend just got his b16 in his crx.. and its fast
Old Mar 5, 2003 | 04:04 PM
Neukin's Avatar
id go for the b18 if i had the choice again. the extra .2 would be nice. i did the b16a1 in my crx but bigger is better and i think that engine weights about the same so theres no reason not to. id go b18
Old Mar 5, 2003 | 04:05 PM
Hybrid Invasion's Avatar
I personally would pick a b-series swap over a D-series SOHC any day, but that's just me. A d16z6(which is what I believe you have)does have potential, but this is really a personal preference kind of decision. A ton of guys here can debate the SOHC vs.the Zc vs. the b-series swaps all day, but what I would concentrate on is this; of the swaps available to you vs. what you already have, what sounds the most appealing to you, and how much does it end up costing? Every single person has a budget, so find what sounds the most impressive to you and stick with it. We'll help you with any additional questions you have. There's a shitload of info on literally every single engine Honda makes, so you shouldn't have a problem finding out the bits and pieces of info about them that you didn't already know. Good luck!
Old Mar 5, 2003 | 04:36 PM
altoid's Avatar
sohc is expensive to make fast, i've put in about 1400 bucks into my sohc and it'll be at most 200 hp at the crank....though this is all N/A. turbo on the other hand would be just like any other engine just about, just gotta have good tuning skills and some wicked sleeves
Nysh
Feb 9, 2007 02:25 PM
EtotheG
Mar 5, 2003 04:54 PM
TurBoXBirD16
Jan 20, 2003 04:02 AM
si91
19
May 20, 2002 04:59 AM
civicraceruk151
May 2, 2002 08:11 PM
