Compression Ratios. Turbo D
Old Mar 5, 2003 | 01:53 PM
T-sohctec's Avatar
Default Compression Ratios. Turbo D
I'm doing a SOHC Turbo setup(Z6 BOTTOM/Y8 HEAD) and need a few things answered.
1.) does anyone know the size of the Y8 combustion chamber.
2.) I'm trying to lower my compression from what I est. to be in the high 9:1 area to a more boost friendly flat 9:1.... Are there any stock Head gaskets for the D series that will do this for me? I know I can get a 2mm aftermarket HG but that will put me at about 8.5:1.
Thanx, any thoughts or imput is more than welcome!
[Modified by T-sohctec, 5:54 PM 3/5/2003]
Old Mar 5, 2003 | 02:23 PM
Charlie Moua's Avatar
Default Re: Compression Ratios. Turbo D (T-sohctec)
try IM ExospeedAMcrx
Old Mar 5, 2003 | 04:07 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Compression Ratios. Turbo D (Charlie Moua)
why do you want lower compression? tunning? it does make sense to lower it (for tunning capacity) but if left it where its @ you'd be just fine. besides you'd get more power from having higer compression then you would from running more boost....
Blaze
Old Mar 5, 2003 | 10:02 PM
T-sohctec's Avatar
Default Re: Compression Ratios. Turbo D (Blaze45)
I'm trying to lower my compression cuz it will be nearing 10:1 with my setup.
that 1 point of comp will make it alot easier for me to tune.
I'm shooting for about 300WHP
secondly I will not have to worry about my gas (or at least worry as much) you can only get so far on pump.
crxhybrid1320
Mar 17, 2010 02:44 PM
yz125rider21
Jan 20, 2006 03:03 AM
josh green
Oct 23, 2004 03:03 PM
mateencrx91
11
Nov 29, 2003 11:40 AM
MUGENTYPER
Feb 6, 2002 06:31 AM
