Hydro B-series ef's Please Help
I searched but could not find it. I need to know which axles are used. I am building up a drag crx and hydro trannys are a lot easier to find parts on. I used a hasport billet kit and modified the tranny mount so it can fit the hydro tranny but I need to know which axles will fit. I have someone that has the driveshatshop stage II axles for a 94+GSR w/abs and I need to know if those will fit. Please help me out. I posted in tech awhile ago but I did not get many response that helped. I think that this would be the best bet for which forum to use.
Thanks in advance,
Daniel
Thanks in advance,
Daniel
I went to a local junk yard and bought a 95 clutch pedal assembly. I have all the hard lines and master cylinder. I just drilled a hole for the m/c line that goes from the m/c to the pedal. It is a pretty straight through change over. But then again my whole car is stripped and is easy to get to the firewall. Good luck.
I have always heard that B-series transmissions can accept any B-series axles. In other words, you can use the same axles with a GSR transmission as with, say, an S1. You just need the proper seals (1990-1993 Integra).
The hasport billet tranny mount is held in place with some bolts. I just took them out and bought a piece of t-6061(I think that is right) aluminum and mounted everything up until it sat correctly. Marked where I need to put the holes and then bolted the aluminum and the hasport mount. Pretty straight through process. I will post some pics next week.
The trick is the intermediate shaft.
You can use any integra passenger side axle from any year 90+, but the driver side axle has to go with the intermediate shaft of the same generation.
You cannot use a 90 driver side axle with a 95 intermediate shaft.
so 90-93 axles need 90-93 intermediate shaft, and
94+ axles need 94+ intermediate shaft.
OOoooh! Got a pic?
I'd prefer to go with the billet mounts (more bling), but was about to go hcp b/c I was gonna cut and reweld the tranny mount for hydro... If I can go with the hasport billet mounts, and somehow rig it like you did I'd definitely prefer that. Pics, measurements, etc, would be VERY much appreciated.
I've got the entire swap ready to go in - just need to figure out which mount kit to use...
415Hatch
11
May 30, 2005 12:36 PM
Charlie Moua
Sep 14, 2003 01:06 AM
to you!
