97 Accord Ecu pinout needed.
Old Mar 5, 2003 | 12:51 AM
Frankie324's Avatar
Default 97 Accord Ecu pinout needed.
Anyone have a scaned or a link that shows what is the ecu pinout for the wiring harness that goes into the ecu. I wanted to do this simple mod that I saw on http://www.ntpog.org/mods/fifth-afc/ecu.shtml and I wanted to know exactly what is the wiring on the ecu harness. I cound not find the white with a yellow stripe and a gold dot on it. The mod simply is to install a toggle switch to reset the ecu instead of inpluging the negative off of the battery that affects the radio and clock ( a real pain in the *** ) also is setting up the toggle switch on the ground should do the same right?????
Old Mar 5, 2003 | 08:49 AM
t0eKnEe's Avatar
Default Re: 97 Accord Ecu pinout needed. (Frankie324)
bump! (__(__)
Old Mar 5, 2003 | 04:07 PM
Frankie324's Avatar
Default Re: 97 Accord Ecu pinout needed. (t0eKnEe)
can anyne help me on this one???
Bodie1234
Aug 12, 2018 07:57 AM
Blake Harvey
Engine Management and Tuning
Nov 15, 2016 01:11 AM
Reno CD-6
Oct 6, 2009 02:01 AM
SOHCrx
Nov 1, 2006 05:32 PM
EuRoBrO
Feb 5, 2003 07:45 AM
