VTEC???????
Old Mar 4, 2003 | 09:30 PM
CRVTEC96's Avatar
Default VTEC???????
Im really having a problem....im running a b20vtec and my vtec doesnt seem to work. It cuts in and out and sometimes it will run for a whole night and then it will work for one gear......I have a OBD2 ECU and a VTEC controller. I checked through all the wiring and i even checked the VTEC conroller itself, Also i am not getting any check engine codes.....so what could be the problem?????????
Old Mar 4, 2003 | 10:18 PM
Ekasey's Avatar
Default Re: VTEC??????? (CRVTEC96)
well there mgood fellow b20 mang i too have this motor and lvoe it my best suggestion would be to check your oil, from there if that is not the problem. Then check to make sure you are seeing the proper volatages at each of your sensors check with a meter by backprobing the ssensor and refer to the oem guide for specs good luck!
Old Mar 5, 2003 | 12:44 AM
CRVTEC96's Avatar
Default Re: VTEC??????? (eLusive ek4)
I already checked all the Volts and sensors, they are all right...Could i possibly have to much oil or not enough.........Ive tried everything and im pretty much out of ideas!!!!!
Old Mar 5, 2003 | 12:52 AM
Frankie324's Avatar
yeah not haing enough oil will make your vtec cut in and out.
Old Mar 5, 2003 | 12:54 AM
CRVTEC96's Avatar
Default Re: VTEC??????? (Frankie324)
How many quarts should the B20 have??????????
teamvirus
Jun 18, 2008 12:58 PM
h22silvia
Nov 9, 2006 07:59 AM
tuckin15s_8315
Sep 28, 2005 10:12 PM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
tvrsir
Jul 15, 2004 06:53 AM
