DP starting to rust!
Old Mar 4, 2003 | 07:18 PM
genop's Avatar
Default DP starting to rust!
My downpipe is starting to rust and I was wondering if there is something I can do about it. Can I sand the rust off and spray something on it?? Is there anything that wouldnt burn right off? I usually wouldnt care, but it just really sticks out in the engine bay.
Old Mar 4, 2003 | 07:22 PM
boostaholic's Avatar
Default Re: DP starting to rust! (genop)
Just sand it off and paint it with some high temp paint.
laughinxxx's Avatar
New User
Powdercoating?!
Old Mar 4, 2003 | 07:26 PM
genop's Avatar
Default Re: DP starting to rust! (laughinxxx)
a coating would probably be best, but when the guy at the muffler shop was installing my downpipe he welded it straight to the exhaust, so I basically I would have to get the whole exhaust done and I think that would be very expensive.....What kind of high temp paint will hold?? I've tried a few kinds on my mani and none of them stayed on very long.
Old Mar 4, 2003 | 07:29 PM
I used 1500 degree VHT and it's held up fine, 1200 degree starts to bubble/crack off.
Old Mar 4, 2003 | 07:51 PM
genop's Avatar
Default Re: DP starting to rust! (boostaholic)
is VHT the name of the company or is it a type of paint?
Old Mar 4, 2003 | 08:51 PM
UberTeg's Avatar
VHT = Very High Temp?
Old Mar 4, 2003 | 08:54 PM
Joseph Davis's Avatar
Default Re: DP starting to rust! (UberTeg)
Uhm, I think it's "Duragon" that's rated for 1800+ deg F. Expect to pay an arm and a leg.
Old Mar 4, 2003 | 09:16 PM
Smashback's Avatar
VHT is the company...you can get it at most speed shops. Their 1500 deg "flame proof" will hold up fine. It works best if you can heat the metal a bit before painting. If not an option, then just make sure you sand and clean the metal with brake cleaner or other strong solvent (not carb cleaner, it leaves a residue)
Old Mar 4, 2003 | 09:32 PM
mamaboy's Avatar
if you can't find the VHT paint try this website
http://www.caswellplating.com/vht/vht_high.htm
MAFDARK
Jan 26, 2007 05:52 PM
egizzle8
Jul 9, 2004 06:31 PM
gapsook
Jun 19, 2004 09:35 AM
Fuster_Cluck
Mar 12, 2004 11:23 AM
nick2kcivic
Oct 1, 2003 11:23 AM
