help me here i dont know what to do
Old Mar 4, 2003 | 07:18 PM
jdhealy's Avatar
Default help me here i dont know what to do
ok i looking to start a new project car del sol b18a/b turbo but should i hold out and get the b18b and i found a 90 b18a i think its a 90 i think i can get it under 400 with ac ps and all that no ecu trans but what do u think i should do i was not sure where to post this so can u just help me out o ya it has 80K mi and any one got a sol for sale dose not need to run thanks
Old Mar 4, 2003 | 08:01 PM
TimoneX's Avatar
New User
Default Re: help me here i dont know what to do (jdhealy)
Well what do you intend to do to this motor? I mean if you intend to replace all the internals(pistons, rods, bearings...) then the milage on the motor won't be all that important. If you just plan to plunk that thing into the shell of your choice w/o any work then you'll want to spend a bit more for something known to be sound.
Old Mar 7, 2003 | 04:02 PM
jdhealy's Avatar
Default Re: help me here i dont know what to do (TimoneX)
i will prolly put a block guard on there and then turbo charge it
Old Mar 7, 2003 | 09:54 PM
TimoneX's Avatar
New User
Your block guard will likely make it run hot. 80k is quite alot for going turbo. I'd recommend rebuilding it while it's out and if you're going to run alot of boost get some aftermarket rods & pistons.
botnutz
Nov 12, 2013 08:06 AM
RSRintegra90
Mar 16, 2005 06:50 AM
importtunerz
Aug 31, 2004 09:09 PM
TheSwift1
Jun 25, 2002 10:23 PM
DeL SLo
Jun 17, 2002 06:15 AM
