What engine is a drop-in replacement of stock 91 CRX Si?
After a good 274k miles, my engine gave up on me. What engine is a good drop-in replacement of the stock engine? I don't want to go B16A or anything, no money.
Thanks,
Thanks,
dont' be a dick dude, that's obvious. You could get a ZC, or you could get a d16z6/y8 and then wire up vtec with a rpm switch.
a ZC
any engine of the 92-00 civic line up...except the 99-00 Si's
basically what u wanna swap will be a SOHC VTEC D16Z6/Y8 or a ZC.....
[Modified by USDM 4G VTEC, 11:07 PM 3/4/2003]
[Modified by USDM 4G VTEC, 11:08 PM 3/4/2003]
could drop a d15b7,sohc zc,dohc zc,d16z,d16y8..any 88-02 d series will most likely drop in..id do a performance rebuild on the d16a6.. a dohc zc ofers most hp stock over the rest...but lack or parts kills it for me
now for my 2 cents. if your not looking to do any mods to it then look for a $100 stocker and save up for a nice b series, but if your looking to spend inbetween $500-$1000 then buy a z6
[Modified by Vinceg99, 10:47 PM 3/4/2003]
How was I being a dick??!!
Rebuilding an old stock motor costs more than swapping in the same block that's used.
where can one find a $100 d16a6? i've been lookin for one for months. cheapest i can find one is $400 for a junkyard engine and i sure as hell gonna buy one of those!
you just told him something he already knew, hell my little brother doesn't know jack **** about cars, but he knows that if his engine goes bad he can always get another one just like it. this dude knew that too, he wanted other options, I'm not trying to be mean, just want you to see the error of you ways,
The exact replacement you can get with good mileage and smoggable would be the SOHC ZC. it the exact same engine, only from japan with a little higher compression. but if you use your USDM manifolds it will pass smog
