Clutch to flywheel fitment issues, any help is a HUGE Help!
Old Mar 4, 2003 | 01:10 PM
TRE_'s Avatar
Default Clutch to flywheel fitment issues, any help is a HUGE Help!
Engine: ZC - Tranny: ZC - Old clutch: ACT SS w/ Xtreme pressure plate, 12lbs flywheel. - New clutch setup: clutch masters stage I, kit.
Heres the delima: The old clutch setup was way too stiff for daily use, so I decdied to replace the clutch/press. plate. So yesterday I pull the tranny off and take the clutch off, and take the flywheel to get resurfaced. Get the flywheel back, put it back on and go to put the NEW clutch on ... but it WONT fit. The new setup is just a little too small. I was told to order the clutch for a 89 tranny(previous owner thought the tranny was an 89 tranny), but it turns out that I have a 90/91 tranny. The place I ordered the kit from is all the way in NJ, while I'm here in AZ.
Option #1: Send clutch kit back, wait to get new clutch kit back. (place waits til they get the clutch back to send new kit, shipping delay would be a pain since the car is in the middle of my friend's shop)
Option #2: Find a flywheel from a 89 crx(since that is what the clutch is for)(is this even an option?)
Option #3: Anything else you can think of?
Which would you do?
Also, since I have a 90/91 ZC tranny, do I order for a 91 CRX si? The place I'm ordering from told me to order the clutch for a 92+ SOHC engine. What is the correct clutch to order?
Thanks for any help, and sorry if this post is a little confusing.
[Modified by glowing_rotors, 2:13 PM 3/4/2003]
[Modified by glowing_rotors, 2:16 PM 3/4/2003]
Old Mar 4, 2003 | 01:41 PM
89civicdx's Avatar
Default Re: Clutch to flywheel fitment issues, any help is a HUGE Help! (glowing_rotors)
88 tranny is diff
89-91 tranny is the same
only 89 clutch disks/pressureplates will fit on 89 flywheels they ususally don't have a sprung hub they will have bushings.
90-91 disks/pressure plates will only fit 90-91 flywheels they have the sprung hub.
you can use a 90-1 flywheel/clutch with a 89 tranny and the other way around too.
Old Mar 4, 2003 | 01:52 PM
TRE_'s Avatar
Default Re: Clutch to flywheel fitment issues, any help is a HUGE Help! (89civicdx)
88 tranny is diff
so are you saying I have a 88 tranny? The old pressure plate looks like it has bushings instead of springs. i'm really confused at this point. the previous owner told me he was positive that it wasnt a 88 tranny, and he was pretty sure it was a 89. So i have a clutch for a 89 crx si, but its too small for the flywheel on the car.
Old Mar 4, 2003 | 02:38 PM
89civicdx's Avatar
no I didn't say you have a 88
When you do engine swaps with d series you have to order the clutch for the the flywheel not the motor.
First question
What year is the clutch for? Is it for a 89? Check the part # with ACT website
Does it fit on your trannies input shaft...if yes and it is a 89 clutch disk then the tranny is a 89-91.If its a 89 disk and it doesn't slide on to the input shaft then the tranny is a 88.
I forgot how to check there is a difference in the # of splines on the input shaft between 88 trannies and 89-91 I believe 88's have 21 splines on the input shaft and 89-91 have 20 splines...but don't go buy that as I forgot which way it is.
What to do now? Well if its a 89 clutch and you have a 89-91 tranny then buy a 89 flywheel.Or return the clutch and get a 90-91.
For sure all of the factory 90-91 clutch disks are sprung hub and the 89's are bushing hub. I have no experience with 88's but I believe they are bushing as well.
If you have a 89 pressure platye it won't fit on the flywheel you have either.
Hope that made some sense.
[Modified by 89civicdx, 3:41 PM 3/4/2003]
Old Mar 4, 2003 | 04:48 PM
TRE_'s Avatar
but the 89 clutch i ordered is sprung hub. did i get sent the wrong clutch?? the old clutch was a bushing type... wow, i'm confused. the car is on the other side of town, or else i would try all those things you mentioned. thanks for all your help man.
Old Mar 4, 2003 | 05:13 PM
89civicdx's Avatar
sorry can't be of more help
Maybe ACT uses sprung hubs for their 88-89's I dunno.
Sorry.
Old Mar 4, 2003 | 06:06 PM
TRE_'s Avatar
Damn. Well thanks for all your help anyway man, you've ben a big help. Does anybody know how to SPECIFICALLY distinguish what year the flywheel is?
Old Mar 4, 2003 | 07:58 PM
TRE_'s Avatar
somebody please help me out! i tried the search function with no luck.
Old Mar 5, 2003 | 01:00 PM
TRE_'s Avatar
bump, i really need some help! anyone?
Old Mar 5, 2003 | 08:08 PM
TRE_'s Avatar
PLEASE help me!!!
Old Mar 5, 2003 | 09:35 PM
the DR.'s Avatar
like he said earlier it depends on the year of the flywheel, from what i've gathered
the sizes are different between 88, 89, and 90-91
the clutch disc sizes would be
88 - 190mm (?)
89 - 200mm
90-91 - 212mm
so measure the clutch disc seating area on your flywheel and go from there
Old Mar 6, 2003 | 07:52 PM
TRE_'s Avatar
Default Re: Clutch to flywheel fitment issues, any help is a HUGE Help! (SlicedBread)
thank you for the info!
Old Mar 7, 2003 | 12:40 AM
HandCommand's Avatar
Make sure you dont order a clutch KIT for a 92+ Civic. Although the pressure plate, clutch disk, pilot bearing, and alignment tool may be the same as the 90-91 Civic/CRX's........the ThrowOut Bearing will be for a HYDRO tranny. Make sure you get one for the cable tranny.
Old Mar 7, 2003 | 12:56 PM
TRE_'s Avatar
Default Re: Clutch to flywheel fitment issues, any help is a HUGE Help! (HandCommand)
so should i just order the kit for a 91 crx? or will that be wrong?
thanks for your help.
Old Mar 8, 2003 | 11:31 PM
TRE_'s Avatar
another bump to try and get a definite answer as to which clutch kit i should order.
1) kit for 91 CRX si
2) kit for 92 + civic(buy throw-out bearing seperate)
will either of these work, or only one of them?
Old Mar 9, 2003 | 05:37 AM
bsawyers's Avatar
First, make sure it's a 90-91. Look at the end of the input shaft, if there are no rings or grooves around it, it's an 88, one groove is an 89, and two grooves means 90-91.
If it's a 90-91, get the 90-91 SI clutch and PP, though I'm pretty sure the 92-95 is the same.
Old Mar 9, 2003 | 09:25 AM
TRE_'s Avatar
Default Re: Clutch to flywheel fitment issues, any help is a HUGE Help! (bsawyers)
cool, thanks for the info man.
EDWINV00SI
24
Oct 13, 2011 06:08 PM
prelude182
Mar 24, 2010 02:29 PM
SIRBUSH
Sep 29, 2002 09:06 AM
