Speedometer problems!
Old Mar 4, 2003 | 09:57 AM
bikeboy80's Avatar
Default Speedometer problems!
yes i know this has been covered a million times before but i just want to make sure im covering everything....
my speedo started to fluxiuate a few days ago, it would drop to 0 and then come back up to normal, earlier in the day i ran thru a huge body of water, so i figured water had gotten in the VSS sensor. I didnt have time to look at it so i continued to drive it, thenit went completly dead and was that way all yesterday, except for once or twice it would start to read for a few secs. the CEL came on once, i restarted the car and it has not come on since (i have not checked the code but i figure its going to be code 17 for VSS)
today i pulled out the VSS and yes it did have some water and corosion in it, so i cleaned it out and scraped the prongs a little to get rid of the build up, i also pulled out the speed gear and it seems to be fine. I also went around the engine bay and pulled off all of the ground conections and cleaned them up, so with all that being done, it still doesn't work
so with all of this, is my next step to pull the cluster? or is there something else i should check first (i'm not looking forward to pulling the cluster out of my teg dash, i'll probally have to at least loosen up the whole dash to get the cluster out )
off topic.... i never relised how hard it is to try and gauge your speed with out a speedo
thanks guys
Old Mar 4, 2003 | 01:50 PM
bikeboy80's Avatar
Default Re: Speedometer problems! (bikeboy80)
anyone?
Old Mar 4, 2003 | 03:22 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Speedometer problems! (burp)
check your alternator fuse. Happened to me. Alt fuse was blown and speedo stopped working, and eventually the battery dies.
Old Mar 4, 2003 | 08:58 PM
bikeboy80's Avatar
Default Re: Speedometer problems! (Emerica)
i'll try checking the fuse tomorow, as for trying someone elses vss, i dont realy have anyone around that i can do that with
Old Mar 5, 2003 | 12:44 PM
bikeboy80's Avatar
checked all the fuses and all of them are fine, is there anyway i can check the vss using an electrical tester? otherwise it looks like i might be pulling the dash apart tomorow to take a look at the cluster, also are there any grounds under the dash i can check? thanks
Old Mar 5, 2003 | 12:48 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
You don't have to take apart the dash to get the cluster out, you're making this too difficult on yourself if you take out your dash or take it apart.
Old Mar 5, 2003 | 05:31 PM
bikeboy80's Avatar
Default Re: Speedometer problems! (SHAUNTS99)
actually, i dont have to pull the dash but i have to pull all the screws so i have some play in it, (bad things of having a teg dash in an eg) to fit the cluster in there i had the loosen all the mounts, put it in and then tighen evertything down sorry if i didn't expain it earlier
Old Mar 6, 2003 | 03:47 AM
Caveman74's Avatar
I have the same problem on my EX. I put a new VSS in and it still hops. It has to be something in the wires or connection?
Old Mar 6, 2003 | 11:30 AM
fathergoose's Avatar
Default Re: Speedometer problems! (Caveman74)
Alternator fuse or the alternator is dead
or bad VSS connection
99Em1Daniel
10
Dec 4, 2010 01:27 PM
ufakeit
10
Sep 8, 2009 05:34 PM
Mike813
Nov 17, 2003 09:07 PM
RCautoworks
Jan 21, 2003 04:24 PM
si91
Jul 9, 2002 09:15 AM
