Can changing shocks and springs correct camber?
I have a 93 civic coupe that used to have some pretty negative camber when I first installed Eibach Sportlines back in 95 (with stock shocks.) Over a year ago, I installed some Ground Controls with KYB adjustables and I've noticed the camber isn't as bad. Checking the tire wear revealed almost the same thing, as the treadwear wasn't as bad as before. Can changing the suspension (i.e. shocks and springs) correct camber as opposed to having only lowering springs with stock shocks, on 93 civic?
Note: I didn't actually measure if the camber was corrected at an alignment shop, I'm just going by the visuals and the treadwear.
thanks
thanks
I'm not really understanding what you are asking. But, negative camber all depens on how low you are dropped. The lower you go, the more negative camber you will have.
The only way to correct camber is using the washer / bolt trick, actual camber kit, or not lowering the car too much. That's about all the options you have.
I have a 2.5-inch drop on the front and rears right now, and the camber doesn't look as bad as it did with the same drop from the Eibach Sportline springs. So what I'm asking is, can the Ground Control/KYB set-up reduce negative camber because it wasn't just installing lowering springs, but changing the shocks as well?
negative camber all depends on how low you are dropped. The lower you go, the more negative camber you will have.
And I think the lower you go, the more toe out increases.
Which is what's really killing your tires.
Quiks66
Sep 26, 2004 01:11 PM
