Slowly increasing PSI....
Old Mar 3, 2003 | 07:51 PM
xstalkrx's Avatar
Default Slowly increasing PSI....
Lets say i start with a 5-7 PSI of boost from the drag gen II kit for my 90 ls teg with 130XXX miles. If I want to get more PSI, all I need is the boost controller that comes with the kit and a tial maybe? Maybe some rods? Rebuild engine? And another thing, how is the bov gonna sound at the low boost level.
Old Mar 3, 2003 | 07:58 PM
MiraiZ's Avatar
Default Re: Slowly increasing PSI.... (xstalkrx)
damn dude...you're are gonna get so flamed!
more boost = boost controller
hey wait a minute..why am I giving you the answers....go do a search a study...it all out there!!
Old Mar 3, 2003 | 08:19 PM
DefiantGSR's Avatar
im willing to bet this guy is going to blow his motor.
Old Mar 4, 2003 | 12:18 AM
pissedoffsol's Avatar
Default Re: Slowly increasing PSI.... (DefiantGSR)
I'm not going against you on that one
Old Mar 4, 2003 | 02:23 AM
ion_four's Avatar
For your own good...use the search feature and all shall be revealed to ye! I can assure that topics like these have been discussed to no end...and...umm...no one really cares what the BOV sounds like, sorry.
Old Mar 4, 2003 | 05:41 AM
n0 iNTegRiTY's Avatar
Default Re: Slowly increasing PSI.... (delvtecsol)
I third that...
Old Mar 4, 2003 | 08:51 AM
SOHC_MShue's Avatar
Default Re: Slowly increasing PSI.... (RAF LTD. 2)
i would get a boost controller and boost to 17psi right away . No engine building needed
Old Mar 4, 2003 | 09:09 AM
Joseph Davis's Avatar
Default Re: Slowly increasing PSI.... (SOHC_MShue)
Boost controllers are expensive, just disconnect your wastegate line and you can control boost level by feathering the throttle.
Old Mar 4, 2003 | 11:09 AM
SOHC_power's Avatar
Default Re: Slowly increasing PSI.... (J. Davis)
Geez, go easy on the guy, he's a noob. Dude just do a search. No need to give him BS advice. He might actually do that stuff.
Old Mar 4, 2003 | 11:11 AM
ekb18c's Avatar
I hope you're joking!
Old Mar 4, 2003 | 01:24 PM
intekragsr's Avatar
I dont believe the kit comes with a boost controller, or maybe i got ripped?
Yes maybe get a few rods and 9.5:4 JE piston since there are 4 cylinders. That will get you a few more psi if tuned right.
And your BOV is going to sound like a trapped pigeon with a rubber band on its neck under the hood with low boost.
Old Mar 4, 2003 | 01:28 PM
intekragsr's Avatar
Actually on a serious note, I would get a compression or leakdown test on your motor since the high milage. If it checks out ok, I would stick with the .45 bar spring on the Tial Wastegate.
If your smart and can afford it, get yourself a Hondata 2b, RC 440 injectors, walbro 255lph intank fuel pump, FPR, and have it tuned. Dont run around on a crappy FMU+inline pump like i did.
Then maybe you can buy a boost controller to up the boost a little.
ochsy03
Mar 24, 2005 08:53 AM
93TurboSi
Oct 16, 2003 06:04 PM
Adub33
May 2, 2003 11:15 AM
mrod006
Dec 2, 2002 07:33 PM
b18c1-ek
Mar 5, 2002 01:17 AM
