1.6 SOHC Non-VTEC Turbo Manifold?
Old Mar 3, 2003 | 07:12 PM
Benny Z's Avatar
Default 1.6 SOHC Non-VTEC Turbo Manifold?
I'm looking for a T3 turbo manifold (external wastegate design) for my 1.6 EK CX engine. I came across the turbo cheap and would like to boost my current engine until I drop in the built B18.
Does anyone make one?
Where can I buy one?
Thanks!
[Modified by Benny Z, 4:14 AM 3/4/2003]
Old Mar 3, 2003 | 07:23 PM
Pengo's Avatar
Default Re: 1.6 SOHC Non-VTEC Turbo Manifold? (Benny Z)
all d-series manifolds should be interchangeable so except for difference in fans/raidators/hoses, you should be able to source out any z6 or y8 manifold that has a manifold that will accept your t3 and you should be set. good luck
-alan
Old Mar 3, 2003 | 08:52 PM
Smashback's Avatar
Default Re: 1.6 SOHC Non-VTEC Turbo Manifold? (Pengo)
The only thing physically different as far as a turbo kit is concerned is the intake manifold. EVERYTHING else is the same.
Old Mar 3, 2003 | 10:04 PM
CzanSOHC's Avatar
Default Re: 1.6 SOHC Non-VTEC Turbo Manifold? (Hatchblack)
https://honda-tech.com/zerothread?id=427032
gmctruck68
May 4, 2008 12:33 PM
fin781
Dec 13, 2007 12:51 PM
92BlackSi
Dec 6, 2003 07:37 AM
