1.6 SOHC Non-VTEC Turbo Manifold?
I'm looking for a T3 turbo manifold (external wastegate design) for my 1.6 EK CX engine. I came across the turbo cheap and would like to boost my current engine until I drop in the built B18.
Does anyone make one?
Where can I buy one?
Thanks!
[Modified by Benny Z, 4:14 AM 3/4/2003]
Thanks!
Re: 1.6 SOHC Non-VTEC Turbo Manifold? (Benny Z)
all d-series manifolds should be interchangeable so except for difference in fans/raidators/hoses, you should be able to source out any z6 or y8 manifold that has a manifold that will accept your t3 and you should be set. good luck
-alan
-alan
Re: 1.6 SOHC Non-VTEC Turbo Manifold? (Pengo)
The only thing physically different as far as a turbo kit is concerned is the intake manifold. EVERYTHING else is the same.
