Threaded IAT sensor compatible with B16A?
Does anyone know if Honda/Acura threaded IAT sensors would be compatible with my 99 Si? I'd like to just weld an aluminum bung on the intake and thread it in for a clean install. I think falconGSR did it with a GM sensor, but he has AEM EMS to adjust the voltage. Where would I look to find the differences between Honda's sensors?
On the 99-00 Civic Si, the IAT is located in the rubber intake boot.
Yes, you can use an OBD1 style IAT sensor with no problems.
Sonny
Sonny
I just assumed that they threaded into the manifold. Are they bolted in? Which OBD1 sensor should I order (which car)? Thanks for the help!
Thanks, sgT! This link has a picture of a '95 Civic intake manifold, but the picture is pretty bad. It looks like the sensor bolts on, though. I'm looking at part #11 here:
http://www.hondaautomotiveparts.com/...NTAKE+MANIFOLD
Am I looking at the right part?
bringmyownend
Dec 16, 2010 08:25 PM
tigueremalo
Nov 10, 2007 04:42 PM
90ZCREX
Sep 27, 2005 10:33 AM
I'm going to stick with what I have, it seems to be holding well.
