99 SI rear sway bar in a 99 DX Coupe
Old Mar 3, 2003 | 04:52 AM
FifthGearOnline's Avatar
Default 99 SI rear sway bar in a 99 DX Coupe
just want to double check this before i go to install it when my parts get here....will this bolt right in, or am i going to need the SI rear lca's?
Old Mar 3, 2003 | 05:52 AM
DragII's Avatar
25 Year Member
Default Re: 99 SI rear sway bar in a 99 DX Coupe (FifthGearOnline)
go look at your lca's if they holes in them, you are good to go.
Old Mar 3, 2003 | 06:05 AM
4g4me's Avatar
you shouldn't, my 98 dx hatch had the holes in them already. Four bolts and lock washers and the 99-00 si setup bolts right on.
Hope your exhaust clears!!!! Cause mine does not, but it is costom, for not thinking ahead.
Old Mar 3, 2003 | 06:43 AM
DragII's Avatar
25 Year Member
Default Re: 99 SI rear sway bar in a 99 DX Coupe (4g4me)
I had to shove my greddy out of the way, but worked. banged around sometimes though.
Old Mar 3, 2003 | 06:46 AM
racecarpete's Avatar
Default Re: 99 SI rear sway bar in a 99 DX Coupe (DragII)
all ek's have the sway bar holes in the lca's you are set man, just make sure you got the endlinks/brackets/bolts with the sway bar setup and it will be straight bolt on. Later
Old Mar 3, 2003 | 10:36 AM
Hatebreed215's Avatar
Default Re: 99 SI rear sway bar in a 99 DX Coupe (SilverCivic2k)
will a 96 dx ej have the holes for the rear bar?
Old Mar 3, 2003 | 10:48 AM
VSMHatcH's Avatar
Default Re: 99 SI rear sway bar in a 99 DX Coupe (Hatebreed215)
ALL Ej/EK chassis have holes for the Rear SI/SiR sway bar
one hole on each control arm
and 4 holes on the subframe (2 on each end where the control arm attaches to the frame)
make sure the bolt that bolts the endlink to the control arm is TIGHT
[Modified by VSMHatcH, 11:48 AM 3/3/2003]
Old Mar 3, 2003 | 11:07 AM
Default Re: 99 SI rear sway bar in a 99 DX Coupe (VSMHatcH)
ok cool.....
Old Mar 3, 2003 | 11:12 AM
IS3Fifty's Avatar
they are all built basically the same way frame wise.
Old Mar 3, 2003 | 12:42 PM
Default Re: 99 SI rear sway bar in a 99 DX Coupe (purek9hybrid)
is their supposed to be a nut for the endlinks to tighten that down?
Old Mar 3, 2003 | 01:02 PM
DragII's Avatar
25 Year Member
http://www.hondaautomotiveparts.com/...REAR+LOWER+ARM
#33
geneeunit
10
Mar 27, 2009 04:12 PM
civexspeedy
Aug 25, 2006 02:43 PM
VeilSide_Mas
Aug 19, 2006 03:39 PM
2khb
Apr 28, 2004 06:50 AM
Spaceballsthelunchbox
Jul 19, 2001 04:37 AM
