Do you suggest buy Bypass Valve .........
Old Mar 2, 2003 | 05:45 PM
Souljahboi's Avatar
Default Do you suggest buy Bypass Valve .........
Old Mar 2, 2003 | 05:59 PM
MugenPoweredLude's Avatar
Default Re: Do you suggest buy Bypass Valve ......... (AzNSouljahBoii)
Its really for peace of mind..if you think you might go thru a puddle thats way too deep and suck up some water than get it i bought it for peace of mind so that in the even i do go thru a deep puddle that doesnt look deep ill be ok..i still put it in neutral when going thru average size puddles tho, just to be sure
Old Mar 2, 2003 | 06:04 PM
RAB's Avatar
RAB
Default Re: Do you suggest buy Bypass Valve ......... (MugenPoweredLude)
Don't buy it not even a peace of mind unless you go through puddles on your way to work.
Old Mar 2, 2003 | 08:42 PM
96LudeSiVTEC's Avatar
Nope. Save you money for something else. As stated before, you have to submerge the filter.
Old Mar 3, 2003 | 10:54 AM
kidaniel's Avatar
The first bypass valve I had for my cold air intake was cracking because whenever you drop a gear and go WOT the jurks the intake, and that caused the sections to that held it intacted to crack. So I bought another bypass valve($45 ) and an extra AEM rubber piece from the shop that I purchased the intake from and put that on instead. So I just put the bypass valve on whenever it rain... sounds like it gets annoying but its not that bad. Takes just about 3-5mins
[Modified by kidaniel, 4:34 PM 3/4/2003]
Old Mar 3, 2003 | 10:56 AM
LostLude's Avatar
Default Re: Do you suggest buy Bypass Valve ......... (96LudeSiVTEC)
Yep, good rule of thumb would be being submerged 16 inches of water, or up the the headlight. If you live in a place where theres always a lot of flash floods get it, if not save your cash.
Old Mar 3, 2003 | 01:29 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Do you suggest buy Bypass Valve ......... (LostLude)
this is what happens when you use a bypass valve on a CAI......
EDIT:: thought i'd add this one too, this is what the cylinder walls looked like
[Modified by Busted97Lude, 6:49 PM 3/3/2003]
Old Mar 3, 2003 | 01:45 PM
apexii's Avatar
Default Re: Do you suggest buy Bypass Valve ......... (Busted97Lude)
Can I vote twice?
Old Mar 3, 2003 | 06:17 PM
stoopid215's Avatar
bwahaha i love the "SMOKE WEED EVERYDAY!!!" everytime i see a poll
Old Mar 4, 2003 | 04:24 PM
One Slow Lude's Avatar
Default Re: Do you suggest buy Bypass Valve ......... (stoopid215)
My friend had a bypass valve on his type R and it sucked the plastic into the intake and got it stuck in the TB, luckily he shut the car off and took it off without any major problems, but he never put it back on or suggested getting one to anyone. If that helps you at all...
Old Mar 7, 2003 | 08:02 AM
madcowdk's Avatar
Default Re: Do you suggest buy Bypass Valve ......... (POSlude97)
There was a recall on those bypass valves. I called aem when my broke and they sent me a new one, that's supposed to be better.. Give em a call.
Old Mar 7, 2003 | 08:45 AM
Default Re: Do you suggest buy Bypass Valve ......... (madcowdk)
ok time to take mine off...thanks for those nightmarish pictures busted!
Old Mar 7, 2003 | 10:39 PM
RAB's Avatar
RAB
Ummmm yeah time to inspect and find a 3" AEM coupler.
Old Mar 8, 2003 | 07:20 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Do you suggest buy Bypass Valve ......... (RY8127)
just go to pretty much any hardware store and buy a 3" PVC to Cast Iron flex coupling
Old Mar 8, 2003 | 08:42 AM
Boostless97Lude
Guest
Posts: n/a
just thougt i'd mention as well, i bought mine AFTER there was a supposed problem, mine was the updated version that wasn't supposed to have problems..... now, the problem i had was the bypass valve stayed open all the time and let in un-filtered air with little debris particles, causing cylinder wall scarring, and a broken valve
Old Mar 8, 2003 | 09:18 AM
madcowdk's Avatar
When you put yours in, did you make one cut in your intake or two? Some people only put one cut in the pipe and don't realize that you have to make two cuts. You actually have to take out a whole section of the intake because if you don't you are adding to the design of the intake instead of just modifying it.
Just a thought.
Old Mar 8, 2003 | 10:12 AM
Boostless97Lude
Guest
Posts: n/a
i know how to read directions......
Old Mar 8, 2003 | 10:15 AM
madcowdk's Avatar
Just checkin'
m0squ1t0
Sep 10, 2009 08:10 AM
bigpoppa15
Feb 10, 2005 12:27 AM
joserodriguez
Apr 8, 2003 12:20 PM
crackhead
Oct 10, 2002 07:24 AM
civic7gen
Jul 24, 2002 05:29 AM
