Camshaft effect on compression?
Old Mar 2, 2003 | 09:37 AM
red91g2's Avatar
Default Camshaft effect on compression?
If i have a motor set up at say 10:1 compression ratio, and i put in a cam with a high lift and duration will this change the compression??? My friend was telling me that it would, but i don't see how because it's not putting the head any closer to the block??? help please
Old Mar 2, 2003 | 09:50 AM
altoid's Avatar
Default Re: Camshaft effect on compression? (b18c93)
changes dynamic compression. its all about the overlap i believe
Old Mar 2, 2003 | 10:49 AM
Urban Business
Guest
Posts: n/a
Default Re: Camshaft effect on compression? (EE4)
cams dont change compression. compressions is changed when the distance from a piston at tdc from the combustion chamber is changed
Old Mar 2, 2003 | 11:02 AM
FullMetalJacket's Avatar
Default Re: Camshaft effect on compression? (limoZeen)
yeh it changes dynamic compression like the guy above said..which is good..if you run high compression and a bigger cam you can usualy run a lil lower octane with out pinging cause of the overlap...
Old Mar 2, 2003 | 12:21 PM
red91g2's Avatar
Default Re: Camshaft effect on compression? (FullMetalJacket)
ok, i'm a little slow so could someone please explain overlap and dynamic compression???
Old Mar 2, 2003 | 02:05 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
http://www.rbracing-rsr.com/comprAdvHD.htm
Old Mar 2, 2003 | 06:06 PM
hmm basicaly a big cam keeps the valves open a lil longer and kinda bleeds compression..thats the easiest way i can think of explainin it
Old Mar 2, 2003 | 06:44 PM
EFsleeper's Avatar
You should try to stay with the compression ratio given by the cams manufacturer. Any company that wont give you at least a ballpark reccomendation I would stay away from.
Old Mar 3, 2003 | 12:12 PM
red91g2's Avatar
Default Re: Camshaft effect on compression? (EFsleeper)
ok thanks guys
pane93civhb
Apr 6, 2009 09:17 PM
.nate
May 6, 2005 06:26 AM
Dan GSR
Aug 27, 2004 07:15 PM
VTC_CiViC
Jun 28, 2002 08:05 AM
evo
Jun 12, 2002 03:45 PM
