help, 88 crx si won't start
Old Jun 4, 2001 | 02:57 PM
MattCRXSi's Avatar
New User
Default Re: help, 88 crx si won't start (harveygigo)
Sounds like a timing problem to me...has anyone been playin with the distributor?
Old Jun 4, 2001 | 05:00 PM
Imyrkos's Avatar
New User
This is absolutly a timing problem. Start with your distributor by taking the cap off and looking at the internals. Check to make sure all the wires are connected that the rotor on the end is not loose (should not turn. This one happened to me not once but three times with different hondas. The screw came out of the rotor and timing went haywire. ) Then check your cap to make sure it is in good condition and move to your wires and plugs. Finally check your timing and belt that is the hardest so do it last hopfully you will get it running
hatchyboy89
10
Jul 17, 2012 02:19 PM
Christopherian1982
Mar 28, 2011 11:35 AM
ef_hopeful
Jan 28, 2008 07:10 PM
RenzoDaPlayboi
Nov 3, 2006 10:01 PM
jaybees
15
Apr 6, 2005 04:30 PM
