Burning oil, smoke only at idle, valve seals?? worth it to replace? help please!
Old Mar 1, 2003 | 09:49 PM
jdm169's Avatar
Default Burning oil, smoke only at idle, valve seals?? worth it to replace? help please!
I recently got a 91 crx si and figured out that it's burning oil. It's pretty bad like it would go from the second dot on the dipstick to the first in like 1.5-2 weeks of everyday driving. I doesnt blow smoke during acceleration or decelleration but it will smoke when it sits at idle for a period of time... then sometimes when it is sitting at idle for awhile you blip the gas pedal it will sometimes smoke clouds.
well after searching for a while on this site i'm thinking it's leaking valve seals. Any other suggestions? BTW it's the stock si motor with i/h/e and i plan to keep it for everyday driving. If it is valve seals is it a difficult fix. You have to take off head and pull out valves?? How much would a shop charge??
Please give me some tips and advice to point me in the right direction, what do you think?
Old Mar 2, 2003 | 01:42 AM
unabonger's Avatar
Default Re: Burning oil, smoke only at idle, valve seals?? worth it to replace? help please! (jdm169)
Check your valve cover seals and if any oil is leaking in your spark plugs. Pull the plugs to make sure they arent went with oil. Also check the oil pan seal. Just some other things to check before pulling off the head. Hope you figure it out.
Old Mar 2, 2003 | 09:27 AM
jdm169's Avatar
Default Re: Burning oil, smoke only at idle, valve seals?? worth it to replace? help please! (unabonger)
When i first got the car i did replace the valve color gaskets and sparkplug gaskets. They were leaking oil down on the plugs. Also I tried wiping most of the block to see where and if it's leaking and it is a little. It doesnt and hasn't leaked on the ground at all so i'm thinking it couldnt be leaking all the oil that i'm putting in like i stated in the original post.
Old Mar 2, 2003 | 09:28 AM
jdm169's Avatar
when searching for help i was reading about something like manifold vacuum and when it's at idle it draws in oil... anyone know about this???
Old Mar 2, 2003 | 10:03 AM
jdm169's Avatar
anyone have experience with this?
Old Mar 2, 2003 | 10:44 AM
Urban Business
Guest
Posts: n/a
my valve seals were shot. i wound up swaping a head to a much nicer P&P one
Old Mar 2, 2003 | 01:56 PM
Eggman's Avatar
I'm having the same problem. Could be oil rings, no?
Old Mar 2, 2003 | 04:16 PM
jdm169's Avatar
Default Re: Burning oil, smoke only at idle, valve seals?? worth it to replace? help please! (Eggman)
if it was oil rings doesnt it blow smoke during acceleration... mine usually only smokes when idleing and at first take off??
Old Mar 2, 2003 | 05:41 PM
Wes d's Avatar
There is higher vacume in the intake manifold and runners at idle or decelaration so it is possible your seals are bad and dried out letting oil past them. Also the valve guides themselves could be worn.
Old Mar 2, 2003 | 06:11 PM
jdm169's Avatar
Default Re: Burning oil, smoke only at idle, valve seals?? worth it to replace? help please! (Wes d)
is there any way i can check for sure? I thinking for the price to fix that and since i would be taking the head off anyway that i should swap the a6 head for a z6 head. I already have access to a z6 head for cheap... hmmm... what else would i need from the z6? IM, something to wire vtec, etc??
cm8719500
Mar 30, 2008 12:09 AM
preludeguy_92
Jun 25, 2005 11:39 AM
turbociv
Jun 3, 2004 12:53 PM
Austin
Feb 20, 2003 12:50 AM
FAST94GSR
Dec 15, 2001 05:07 PM
