b16a2 wiring ?
Old Mar 1, 2003 | 11:08 AM
jcivic's Avatar
Default b16a2 wiring ?
i bought a wiring harness for my swap it has does not have the crank flactuicion sensor harness or nothing connected to those slots in the ecu .should i add them?
Old Mar 1, 2003 | 11:09 AM
fowler!'s Avatar
Default Re: b16a2 wiring ? (jcivic)
Depends on which ecu you are using.
More specifics? Car, ecu, which wiring harness you bought...
Old Mar 1, 2003 | 12:15 PM
jcivic's Avatar
Default Re: b16a2 wiring ? (fowler)
im putihg a b16a2 into my 98 civic ,i will be using a 99-00 si ecu.
Old Mar 1, 2003 | 12:29 PM
fowler!'s Avatar
Here are some things that you need to know:
1. You can't use the 99-00 B16 ecu in a 96-98 civic without using a conversion harness.
2. You can only use a 96-98 civic wiring harness (Ex harness is what you need).
If you get an ex wiring harness, you won't have to worry about the crank fluxuation sensor seeing that it's already on the harness.
From what I get, you're trying to use an OBD1 engine harness. It's not possible, you need either use your dx harness and add a couple wires or find an ex and extend the ones you need to.
Old Mar 1, 2003 | 02:22 PM
jcivic's Avatar
i rewire it to fit the ecu,the wiring harnes i think was from a integra.
Old Mar 1, 2003 | 04:30 PM
fowler!'s Avatar
Throw it away or sell it. Get a wiring harness from a 96-98 Ex Civic.
Old Mar 1, 2003 | 05:33 PM
tnbigdawg's Avatar
im using an 99-00 Si harness and ecu to run my LsVtec(OBDII setup). You have to do some rewiring but I recommend getting a conversion harness. Should be plug and play.
Old Mar 1, 2003 | 06:04 PM
prada_2o0o's Avatar
Default Re: b16a2 wiring ? (tnbigdawg)
i put a b16a2 into my 97 coupe si-g... i had to change the engine harness and harness behind the dash to the 00 si harness and it was all plug and play
Old Mar 1, 2003 | 06:16 PM
EK MONEY's Avatar
Default Re: b16a2 wiring ? (prada_2o0o)
coverting to 99 from 98 is far from plug and play..
EKcivicEK
Oct 25, 2009 09:00 AM
NegativeXero
Jun 1, 2007 10:37 AM
gtowni3
Sep 26, 2004 10:05 PM
TheBestCRX
Jan 28, 2003 07:08 AM
servion
Jul 9, 2002 10:44 AM
