compression test
Old Feb 28, 2003 | 03:37 PM
lsvtec4door's Avatar
Default compression test
whats up...i just did a compression test on my engine ...im using a 95 gsr motor with a drag 3 kit in a 95 hatch the motor has about 70k on it ..i also forgot to pump the gas while i was doing it. anyway the numbers where
cylinder#1...200
cylinder#2...180
cylinder#3...190
cylinder#4...195
anyway are these numbers fine or are they bad...the engine was at normal operating temp... i pulled the ecu plug but i FORGOT to push the gas pedal to full throttle would that effect the numbers...thanks alot let me know
Old Feb 28, 2003 | 03:54 PM
leadfoot78's Avatar
Default Re: compression test (lsvtec4door)
Do it again and you will find out if it makes a difference, I tested my GSR but I pressed the gas down. Mt numbers are 220/210/215/215 but mine is a JDM so it will have a little more than a USDM.
Old Feb 28, 2003 | 04:01 PM
nonvtec allmotr's Avatar
looks good for 70k
97civic07gsxr
17
Mar 5, 2009 12:30 AM
marc.ejay-twenty
Apr 15, 2004 03:56 PM
lsvtec4door
Mar 4, 2003 06:13 AM
lsvtec4door
Mar 2, 2003 06:59 PM
jaredfmn
May 30, 2002 11:33 AM
