H22 EG axle problem FIXED!
Old Feb 28, 2003 | 08:25 AM
KStuned's Avatar
Default H22 EG axle problem FIXED!
OK, so I get my h22 EG swap started for the first time last night, started right up by the way! FULL REBUILD and my first h22 into a civic, and yeah, started right up and NOT ONE CEL! Alright, enough gloating.
Anyway I get done and let it idle for a while, I am checking things out and then I go for a drive, all is good until I get above 33mph, anything at that speed or above and the car shakes like crazy!!! I mean shaking like the dash is going to jump out, the shake is in or out of gear, and with the clutch engaged or disengaged so I figured it had to be an axle. So I rack my car, and I can't visibly see anything, so I took out my brand new axles and went to talk to my boy at NAPA, he handed me some new ones. I put these ones in and it still does it! At this point I know it has to be axles or the hub, something in the chassis drivetrain. So the last thing I do before I go home is raise up the car, because it was sitting kind of low, so I raised up my coilovers, and PROBLEM SOLVED!!! H22 civics don't like to be low!!! So now all I have to do is figure out how to be able to keep my car low and not have axle problems!
Old Feb 28, 2003 | 12:51 PM
prospeed's Avatar
Default Re: H22 EG axle problem FIXED! (Hondaddict)
The reason why you have problems with the axle and the reason why many other h22a swaps turn out bad is because of the axle length. If you use the proper length axle you can lower your car all the way down!
Old Feb 28, 2003 | 01:53 PM
96-EJ6 B18C's Avatar
Default Re: H22 EG axle problem FIXED! (prospeed)
Thanks, I plan to upgrade real soon, I just needed something to get it up and running for the 1000 mile break in!
Old Feb 28, 2003 | 02:08 PM
prospeed's Avatar
Default Re: H22 EG axle problem FIXED! (96-EJ6 B18C)
good luck with it!
Old Feb 28, 2003 | 02:12 PM
chad's Avatar
Moderator
i have worked on a few h22 eg's that did this.....i told the owners they had to raise the car up....but they didn't cause it didn't look right....they just kept replacing axels every 2 weeks!
Old Feb 28, 2003 | 04:15 PM
RedlinedVTEC's Avatar
Props man, looks really good. Who did the sleeves?
Old Feb 28, 2003 | 04:19 PM
EK_logkomlki's Avatar
so what would be the proper axle for an EK-22 swap??????????
Old Feb 28, 2003 | 04:48 PM
EK MONEY's Avatar
all about axle length
Old Aug 27, 2003 | 07:10 PM
JdmCIVIC853's Avatar
Default Re: H22 EG axle problem FIXED! (Peagreenhatch)
so if i buy the axles from driveshaft shop my car should stop vibrating?
My only vibrates when i turn left,
I had order some coilovers so i could raise my car up...but i got jiped which sucks b/c thats a waste of alot of money....soi dont wanna trying buy another set of coilovers...so i plan on going driveshaft and i just wanna konw if they'll stop it
Old Aug 27, 2003 | 07:19 PM
mister2racer's Avatar
i like this thread I need the info as well. I am going with driveshaftshop.com axles but i am definatly curious if there will be a problem when low. i want to keep my front end very low to help launching.
-charles
Old Aug 27, 2003 | 07:42 PM
.nate's Avatar
Default Re: H22 EG axle problem FIXED! (JdmCIVIC853)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmCIVIC853 &raquo;</TD></TR><TR><TD CLASS="quote">so if i buy the axles from driveshaft shop my car should stop vibrating?
My only vibrates when i turn left</TD></TR></TABLE>
I encountered the very same problem with my GSR swap into a 92-95. I changed out the differential, axles, wheel bearings.. the works. Nothing helped. I wonder if it was the rack now that I look back.. or it could of been it being too low or something.
Old Aug 27, 2003 | 10:58 PM
~~~InNeEdFoRsPeEd~~~'s Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmCIVIC853 &raquo;</TD></TR><TR><TD CLASS="quote">My only vibrates when i turn left,
bump this up, i got the same problem
Old Sep 11, 2003 | 03:18 PM
laosb904's Avatar
oh man i just thought it was my car ****** up. my car vibrates turning left and going stright. when i turn right it goes away.
Old Sep 11, 2003 | 03:53 PM
fastwanabe's Avatar
Default Re: (laosb904)
usually axles shaking in a H22 eg is due to inproper lengths of the shaft, I use 89 teg axles cause the axles were shorter and that fixed MY prolem however it caused another. By the axle being short it ended up pulling the axle boot to the point where it would pull the axle out of the tranny, so I fixed that problem by simply swapping the tranny side cv cup with one from a prelude and it has never backed out again.
Old Sep 11, 2003 | 09:44 PM
* B A N N E D *
Default Re: (fastwanabe)
with this problems with left turn or turning left, which side axel is the cause of it? driver or passenger?
Old Sep 11, 2003 | 10:44 PM
RangerDan's Avatar
Default Re: (~~~InNeEdFoRsPeEd~~~)
Hey Reed whats up? Glad to hear you got that thing up and running. In case any of you doubt the time and effort this kid put into his car dont.
Im not sure if I could have that much patience.
Was up in your area and was gonna stop by the shop but we had a two day race and time flew by...
lol You may not remember me but I stopped by with my brother (were the old guys) who lives in that area earlier this year and I had driven my black si with the itr swap up from Wyoming.
BTW I was racing autox with one of your boys with an eg and a h22 swap...cant remember his name but he has Club Si stickers on it. Oh, and I smoked him
Old Sep 12, 2003 | 03:08 PM
jdmh22bubble's Avatar
okay i had the same problem with my H22 EG and i finally spent the money and got some drive shaft shop axles and POOOOFFFFF!!!!! problem fixed no more vibration. your right H22 EG's don't like to be low-untile now-now they love it!!!!
Old Sep 12, 2003 | 04:27 PM
* B A N N E D *
Default Re: H22 EG axle problem FIXED! (jdmh22bubble)
which side did you have the vibration on? how low is your car sitting? photos happy for ya man
Old Sep 13, 2003 | 07:39 PM
sonnyboi612's Avatar
Default Re: H22 EG axle problem FIXED! (~~~InNeEdFoRsPeEd~~~)
I have the same problem, when i go left the car vibrates like crazy.
So, I got 2 new axles put in but now the when i go right in vibrates even worst than before, but it is fine when I go left.
What axles do I need to fix that.
Tech_Greek
Jul 30, 2009 06:09 PM
Tech_Greek
Jul 28, 2009 06:58 PM
rmnS2K
Transmission & Drivetrain
Oct 5, 2008 06:39 PM
jdmegh
May 25, 2007 07:21 AM
Equilibrium
Jun 8, 2005 01:40 AM
