questions for the d series gurus...
A y8 head on a d16a6 block with a y8 IM....is the compression too high for an 8 psi t25 custum setup
will a 95 d15 head work on my d16a6?
just the head
will i lose hp?
can i still use my d16a6 timing belt...
just the head
will i lose hp?
just the head
will i lose hp?
just the head
will i lose hp?
but will a d15 head off a 95 civic (non vtec) work on my block with my timing belt???
and how much powere will i lose
[Modified by anti-ricecake, 10:25 PM 2/27/2003]
What D15 head are we talking here? the b2/b7/a6 as far as I know are all the same castings. So you would have no change.. The only difference is the cams.
The B6 and B8's are all 8valve and ****.. dont even **** with that.
Mini-me Turbo... ahem.. Since I have done 2 of them, I will tell you this, they can be a bit tough to control, especially since you need to take alot of timing away, almost more than 1.0 degree per psi, (on the top end) and about .5ish on the bottom end, this is where a standalone system comes in, or the use of Zdyne Gold SECU. You probably could get away with a afc hack (using 450's) and a MSD BTM, but the boost is going to have to be reasonable. (5-8psi) The high compression of the mini-me makes it very easy to detonate.
But they do run out pretty strong.
Jeff
Jeff
just the head
will i lose hp?
just the head
will i lose hp?
Either way, use the timing belt according to the head. (ie, B7 head, B7 timing belt, Z6 head, Z6 timing belt) I wouldn't be surprized if the A6 T-belt fit the B7 head though.
You can use any D-series headgasket for that set up. I would recommend the Z6 or Y8 heagasket, they are very strong and increase your compression ratio.
[Modified by MrTodd, 1:24 AM 2/28/2003]
[Modified by MrTodd, 1:25 AM 2/28/2003]
well i have a new timing belt and my valve stem seals are fucked so im losing a lil oil
so i wanted to swap the head
not yet tho but in like 2 months
waht should i do?
waht should i do?
in the car its kinda a pain.. you will need to fill the cylinder full of air. and remove the valve springs. Pull the oil seals off (normally plyers work) and install the new seals, I use deep chromie sockets to tap them in (with a small amount of greese) Then you will need a valve spring compressor to reinstall the valve spring. and thats it.. walah.
Jeff
Jeff
silly_mang
Oct 24, 2008 11:43 PM
yrulkn@me
Jul 2, 2007 01:08 AM
pip9
Apr 3, 2006 07:09 PM
hatchback19
Feb 29, 2004 10:56 AM
