Help... can't decide which 5th gear to swap in
Old Feb 27, 2003 | 04:46 PM
E-lude78's Avatar
Default Help... can't decide which 5th gear to swap in
I'm rebuilding my JDM YS1 cable tranny. Here are a few choices of 5th gears from cars made here in NA.
Del Sol B16A hydro 5th - 0.848
92-93 'teg LS/GS cable 5th - 0.742
94+ 'teg GSR hydro 5th - 0.787
My current 5th gear - 0.880 <--- seems to be the highest 5th gear ratio of all the B-series tranny's.
Now I've heard some guys here have done the LS 5th gear swap and that its great for hwy driving. Will the hydro 5th gears fit my cable tranny if I decide to use those?
[Modified by Mista B-one-seven, 5:47 PM 2/27/2003]
Old Feb 27, 2003 | 04:57 PM
bryant's Avatar
Default Re: Help... can't decide which 5th gear to swap in (Mista B-one-seven)
I didnt even know you could put USDM gears in the JDM tranny.
Old Feb 27, 2003 | 09:01 PM
E-lude78's Avatar
Default Re: Help... can't decide which 5th gear to swap in (Bryant)
sure you can
Old Feb 28, 2003 | 07:24 PM
smokey2.0's Avatar
just use a 94+ ls, since your fd will be a 4.40 this will make that 5th gear be a bit slower(rpms) than a hydro gsr 5th gear! you'll like it!
Old Feb 28, 2003 | 07:38 PM
FourthGenHatch's Avatar
If I were you I would get a high *** 5th gear so I could get decent gas mileage.
Old Mar 2, 2003 | 07:43 PM
bryant's Avatar
sure you can
Alright bumpin' because i would like more info on how to put a longer 5th into a JDM J1.
Old Mar 2, 2003 | 07:47 PM
smokey2.0's Avatar
the easy way, take the tranny down your self and take it to your local tranny shop. they should charge you no more than 250 to swap the gear in, since it's the first gear there once the case is opened! or you could buy a helms manual, and take a crack at it!
Old Mar 2, 2003 | 07:48 PM
smokey2.0's Avatar
Default Re: Help... can't decide which 5th gear to swap in (smokey2.0)
by the way, where did you get this tranny from? and how much did you pay? i'm interested in one!
Old Mar 2, 2003 | 07:49 PM
bryant's Avatar
So all I need to do is decide what 5th gear I want (doesnt matter weather its a hydro or cable tranny?) and then take both of those to my local tranny shop?
EDIT: J1 I have I got with motor.
[Modified by Bryant, 9:50 PM 3/2/2003]
Old Mar 2, 2003 | 07:52 PM
smokey2.0's Avatar
it can be either hydro or cable, as long as it's from a YS1 on the cable side, or from a 94+ hydro ls(i think s80)!
Old Mar 2, 2003 | 08:08 PM
bryant's Avatar
so it has to be from a YS1 or a S80?
Old Mar 2, 2003 | 08:11 PM
smokey2.0's Avatar
you got it! so how much did you pay for the tranny? and where did you get it?
Old Mar 2, 2003 | 08:13 PM
bryant's Avatar
Came with my motor. But a friend just picked one up for $400 from a guy in socal.
EDIT: oh yeah, for YS1 is that the 90-93 teg LS tranny or 92-93 GSR tranny or the JDM tranny?
[Modified by Bryant, 10:15 PM 3/2/2003]
Old Mar 2, 2003 | 08:18 PM
smokey2.0's Avatar
usdm ys1 cable non gsr!
your friend found one hell of a deal!
eviled
Oct 2, 2007 01:47 PM
fizic
10
Feb 23, 2004 08:03 AM
teg9
Jan 19, 2004 09:38 PM
EFSiR
Jun 20, 2002 06:34 PM
FSTASNTZ
Mar 17, 2002 10:31 PM
