wires thru the firewall
Okay, i give. I need to run some wires thru the firewall in my 97 Honda Civic HX but i can't seem to find a current opening i can use anywhere. I don't want to drill a new hole cause i can't tell if there is or isn't something in the way on the other side. okay, okay, i know i'm looking for the easy way to do this but i'll also take the hard way if anyone can help. thanks.
There is a grommet under your battery tray on the passenger side. Remove it and snake a coat hanger through the hole.. It'll take some work but it will come out under the carpet on the passenger side.
I pushed mine through the grommet under the passengers side of the dashboard *underneath*. Ive run wires for my alarm and my power wire for my sub...so it shouldnt be hard to get 1 or 2 in there!!
Put some silicone on the wire where it goes thru the gromet. It'll keep any water from seeping into the car and under the carpet. It only takes a sec, and will prevent a huge problem in the future.
good luck
good luck
Ben Scholer
Mar 7, 2016 05:17 PM
Mr. Softee
Jul 4, 2002 04:28 PM
