eg civics with b18b
Hey guys...did anyone with a eg civic with a b18b swap need anything extra to complete the swap like a different shift linkage or other stuff?? Im swapping that motor in soon and i jus wanted to know so everything will go right...thanx
There are a few little tricks but nothing hard to figure out. The integra lower torque mount need to be cut a little to fit...and you should go ahead and get some motor mount inserts. A short shift kit is easy to install while your at it. Clutch and flywheel is something you should do when the motor is out of the car if you have the cash...it's basically a plug and play swap. Good luck
b15
13
Jan 16, 2010 04:47 AM
fasterthenmost
Oct 14, 2005 07:57 PM
rasinhell
19
Jul 29, 2005 09:03 PM
drkblue_civic
Aug 24, 2002 01:25 AM
