does a B18b need a hasport mount kit??
I was told I needed to buy a 500 engine mount kit I thought I could use stock...guess not let me know...thanks
[Modified by drkblue_civic, 12:22 AM 8/24/2002]
New User
Re: does a B18b need a hasport mount kit?? (drkblue_civic)
He was talking bullshit! Probably to scam you off some money. The ones from the integra bolt right on to the eg chassis.
man, i no EXACTLY what your going thru. i had boughten my car with a b18b in it in janurary, well.. **** happens, i've done sum more mods, and i blew my uper left (drivers side) motor mount apart 4 nights ago. not knowing exactly which mounts the previous owner had used i had to research it some more.. all i could find was this hasport ****, and i'm canadian, so 499 american hurts like a bitch, basically what i'm saying is **** HS, stock works, bear in mind your missing one tranny mount, i've boughten the urethane inserts by energy suspension, 60 bucks, helps alot, and stops the lateral torque. good luck wiht ur moding.
usually the weakest mount is the drivers side mount especially if you beat the hell out of the car by launching.. hope u can get your swap in and you should do more research before putting all your money out for something that you lack Basic knowledge of..no reason to Help screw yourself over by ignorrance.. don't get me wrong I mean this in the most respectful way so goodluck and hope you can get the swap done soon..but upgraded mounts are always a good thing just a tad more vibration but gives a better feel and less engine movement
FortunateFool.
08-13-2002 08:17 AM
