Can Koni Yellows LIFT?
Old Feb 26, 2003 | 06:31 PM
AcuraEL's Avatar
Default Can Koni Yellows LIFT?
Simple question.
I was wandering if I'll be able to lift my vehicle a little with those shocks? (99 sedan) my front is dropped too much on those cut Sport Neuspeeds, I'd like to be able to lift it just a little (one finger gap).
I heared that Konis yellow can lower, but can they lift?
thanks!
Old Feb 26, 2003 | 06:39 PM
b16 matt's Avatar
Default Re: Can Koni Yellows LIFT? (AcuraEL)
Um your shocks dont have any thing to do with it.
Old Feb 26, 2003 | 06:42 PM
Rratedcivichatch's Avatar
on normal koni yellows , there are 3 perches to lift the car. im guessing you have them in the middle so you can lift it one notch. on neuspeed yellows there are 5 perches so you can move it up 2 notches. so yes you can move it up. but 1 perch is minimal at most. good luck
Old Feb 26, 2003 | 07:12 PM
SpooN Man's Avatar
Default Re: Can Koni Yellows LIFT? (Rratedcivichatch)
Buy a good NON cut spring
Old Feb 27, 2003 | 04:50 AM
kommon_sense's Avatar
Default Re: Can Koni Yellows LIFT? (SpooN Man)
yes, you can use the adjustable perches on the yellows to raise the car a bit.
Old Feb 27, 2003 | 04:55 AM
toEknEEg's Avatar
Default Re: Can Koni Yellows LIFT? (kommon_sense)
yea you can adjust it. there are four perches i think. about an inch in each direction. not sure. i love my konis. they feel really good.
slammin86
Suspension & Brakes
Jan 20, 2009 05:00 AM
yaoming315
May 7, 2007 08:12 PM
spdster
Jul 14, 2002 10:51 AM
Krakhor9
14
Jun 10, 2002 07:30 PM
taytay333
Mar 26, 2002 03:54 PM
