hey guess what? speedometer isn't working
Old Feb 26, 2003 | 03:56 PM
Ladysman_civic's Avatar
Default hey guess what? speedometer isn't working
OK, so my speedometer stopped working on my 96 EX...
So i am pretty sure its my speed sensor! dammit... so do you have any suggestions on what else it could be, or where i can get a speed sensor for cheep?
Thanx
Old Feb 26, 2003 | 03:58 PM
grenthang's Avatar
Default Re: hey guess what? speedometer isn't working (Ladysman_civic)
Try a junkyard
Old Feb 26, 2003 | 04:09 PM
Mr HYDE's Avatar
Default Re: hey guess what? speedometer isn't working (grenthang)
for the hell of it check the plug goin in to the tranny mine fell out and my speedometer didnt work till i pluged it back in.
Old Feb 26, 2003 | 04:12 PM
smnowell's Avatar
Try a junkyard
I would also suggest a junk yard or try your local mechanics shop, they might have some lying around. I know a shop around my area has old d-series motors from swaps they have done. Those ******* VSS go bad all the time. What are the symptoms of yours? When mine went bad, my speedometer would jump around from like 0 to 20 then to 60 then back down to 0 then to 97 etc...basically it was jumping around like it was possed. It was really annoying and it gave me a CEL. If you don't have a CEL, then it most likely isn't your VSS. Could be the actual speedometer itself (I have also had this go bad on me) in which case you can order a new speedometer gauge from http://www.hondaautomotiveparts.com
Old Feb 26, 2003 | 07:30 PM
Default Re: hey guess what? speedometer isn't working (gen 5 hatch)
thanks a ton... i will check that... we recently had a bunch of snow and ice, and me and my friend both took our civics out having drifting good time... so that may be it
Old Feb 26, 2003 | 07:37 PM
M-EJ1's Avatar
If it turns out to be the VSS, I have a spare I can part with, let me know.
Old Feb 26, 2003 | 07:41 PM
Default Re: hey guess what? speedometer isn't working (b16a ferio)
thanks for the help dude...
Old Feb 26, 2003 | 07:42 PM
Default Re: hey guess what? speedometer isn't working (M-EJ1)
REALLY?!? do you know if it would work on my D16Y8... and how much would you take for it...
that would be a life saver
Old Feb 26, 2003 | 08:07 PM
turbod16y8's Avatar
my speedometer didnt work ..found out it was a blown fuse cuase by a short in the o2 sensor wire.
Old Feb 27, 2003 | 08:22 AM
Default Re: hey guess what? speedometer isn't working (turbod16y8)
which fuse is it?
Old Feb 27, 2003 | 08:24 AM
this really suck, i hate having anything wrong with my car!!!
but the good thing is my odometer doesn't work since my speedometer stopped working also... so i havent gained a mile on my car in 5 days...
Old Feb 27, 2003 | 08:25 AM
and counting....
Old Feb 27, 2003 | 11:36 AM
redturbo0
25
Jun 10, 2013 05:36 AM
Freckles
Aug 20, 2012 10:30 PM
s0ulj3r
Feb 17, 2008 10:53 PM
aziaticvang
Jan 13, 2008 06:35 PM
bg-33p
Feb 12, 2005 10:33 PM
