y1 lsd in a j1
think that you got it reversed. Like your topic says, i think you mean can you put the y1 lsd into a j1 trans (since the j1 never came w/ lsd). Since it's a b series cable trans, i do believe that you should be able to put the y1's lsd in it...just like you can put in the final drive out of another b series trans. not 100% sure tho
Yes you can, but you will have to modify some oil baffles inside the trans casing. Nothing major. Also the y1 trannies have a 4.266 final drive, whereas the J1/S1 has a 4.4 final drive. You can only drop it in if your swaping the countershaft along with it. The ring gears are not interchangible either, so you cant go that route.
spettinger
Nov 1, 2002 03:27 AM
