shifter???
I have 4 spd std hb. My shifter is very loose. Even when I shift it into gear the shift lever moves around as if it were in neutral. The shifter lever doesn't move back into the center like its suppose to. I was told it could be the bushing. Can someone tell me how to fix this problem?
You have 2 choices-find a set of Energy Suspension poly ones or go to your local Honda dealer and pay about the same-BUT-get all of the pieces. This includes the nylon socket that the shifter rests in and the rubber boots and O-rings.
Sounds like the plastic spring (kind of a round plastic cage) that goes around the shift lever pivot is busted. you can get a new one at Honda cheap. I am guessing it is not your bushings based on the symptoms you describe (although the poly bushing kit is a nice addition).
mrbuddha
Jan 28, 2011 12:30 AM
jacoop86
10
May 23, 2006 11:53 AM
mafioso102
Jan 31, 2002 04:38 AM
