TPS problems need help
Old Feb 25, 2003 | 07:01 AM
SpoonFedEF7's Avatar
Default TPS problems need help
aight, I just got some JG cams put in my ZC and they put in a new distrubtor but, when i got the car back it was throwing a code 7 (tps). Since I got the car back I have replaced the tps with another one and i still get the code 7 and it also started throwing a code 9 (tdc) so i have to get another distrubtor. My question is would the bad distrubtor cause part of the code 7. I have reset the ECU like 20 times and have adjusted the TPS but still same thing.
oh and if it helps i have a JG TB that i'm using on it but before I got the cams it was not throwing a code 7.
sorry if this doesn't make sense or if i babble I just want my car running right again
Old Feb 25, 2003 | 07:43 AM
zCivic's Avatar
Default Re: TPS problems need help (SpoonFedEF7)
Is the voltage correct at closed and WOT throttle when you test is?? It has to be in a specific position at closed throttle or it will CEL. Helms has the testing for it I can update this with the instructions after work if that will helps. Pretty sure 0.5 volts closed and aprox 4.5 WOT testing at TPS
Old Feb 25, 2003 | 08:08 AM
Default Re: TPS problems need help (zCivic)
yeah if you can do that please do so. Also i'm not sure how to test it, i will probably try some more things and if that does not work i will take it back to the shop that put the cams in to get them to fix it since they cause it in the first place
Old Feb 25, 2003 | 08:09 AM
also is there any easy fix if the voltage is wrong?
Old Feb 25, 2003 | 08:33 AM
zCivic's Avatar
did you take the TPS off the T/B at all?? Its hooked up correct?? if you've had the head off either or could happen. To test it you need a multi meter. I'll get you the info for sure tonight
Old Feb 25, 2003 | 08:39 AM
yeah when i got the JG tb it didn't have a TPS so i just switched the one off my old tb to the jg and hooked everything up and it worked perfect with no codes but the minute i got my car out of the shop when they but the cams in it started throwing the code. everything is hooked up and when i take the TPS off the TB i can hear it click back from where it was. we didn't have the head off just the distrubtor and valve cover but it was off for over 24hrs. yeah please get me that info as i need/want this fixed so i can get my cam gears tuned at the dyno
Old Feb 25, 2003 | 03:20 PM
zCivic's Avatar
here you go
[Modified by zCivic, 7:25 PM 2/25/2003]
Old Feb 25, 2003 | 03:25 PM
zCivic's Avatar
sorry for large pics but only way to read them
Jej2386
Feb 18, 2010 11:27 AM
Juan_Mitosis
Feb 4, 2008 04:39 PM
Walshie
11
Dec 1, 2006 01:42 PM
TegLove
Apr 23, 2004 11:24 AM
rice_classic
Jul 16, 2003 05:51 PM
